Location: Saint Louis, Missouri, United States of America, Earth
Send a message via AIM to Allldi
Question Replacing check valve
Has anyone replaced the check valve in the fuel system? I'm having a hot start problem and I'm thinking my check valve might be the culprit. I ordered a new one from Pelican but I'm not sure where it goes. I looked around by the fuel pump and the fuel filter but I didn't really see it. Am I just missing it, or is it in a totally different place? If I correctly understand the check valve's function, then I assume that the valve should be somewhere in the output line after the fuel filter. Also, do I really need to relieve the fuel pressure before I replace it? If so, do I just pull the pump fuse and run the engine until it quits, or is there a better way to do it? Any help would be appreciated.
Ryan
1991 944S2 coupe
Old 10-13-2001, 05:08 PM
Post
Hi Ryan,
Just had my check valve replaced, but as my mechanic did it, I'm a little short on details. He said the valve screws into the fuel pump itself, which is located in a recess on the underside of the tank. The plastic cover over the tank must be removed for access.
Yep, pulling the fuel-pump relay while the engine is running is a good way to de-pressurize the system. BTW, replacing that valve totally fixed the hot-start problem I was having. Good luck!
--Doug
Old 10-13-2001, 05:45 PM
Post
replaced one. they are brass & screw into pump.
Old 10-14-2001, 07:58 AM
Question
Does the valve screw into the input side or the output side of the pump? If it's the output side, do I have to remove that big plastic cover that covers the tank with the strap around it or just the little cover that covers the rear of the pump? If I have to remove the big cover, how should I support the tank while I remove the strap in order to remove the cover?
Ryan
1991 944S2 coupe
Old 10-14-2001, 03:03 PM
Post
Hi Doug,
I have a hot start problem too. Since cold start is OK on my car, (even after it sits for a long time) I am wondering if check valve will fix my problem. Before you change the check valve, do you have trouble to start your car when it is cold?
Thanks,
George
91 S2 Cab
Old 10-16-2001, 10:07 AM
Post
Alldi,
it is on outputside of pump & with banjo bolt, I think little cover is all you have to remove.
Old 10-16-2001, 01:27 PM
Post
gz,
no hot start is a symtom of bad check valve.
Old 10-16-2001, 01:28 PM
