Macfreak007's Avatar
Send a message via AIM to Macfreak007
need purchase advice
I have decided to go ahead and get new konis for the front what exactly should i buy and from where? wil i need to buy new springs? or what and can i do the whole swap myself? i have taken struts out before, i ask about the spring because i have a used strut that i am not sure if the spring is the same as the konis that are on there.
'84 944na -- Sold
'84 944na -- Sold
'85 944na, -- Sold
Old 02-19-2004, 06:08 PM
Blackfoot's Avatar
I'd opt for adj. Konis, if you can still get them for your car, keeping the stock springs, which will let you retain your ride quality. Then if you needed more, going with sway bars.
Less than 60k on Koni yellows?
____________
2 legit to drift
Old 02-19-2004, 06:26 PM
that is what I want , the car has koni's on it, but the passenger one was bent so a used strut was put on, so it will need new struts on the front. Are the struts from paragon good? I want the best koni yellows i can get
'84 944na -- Sold
'84 944na -- Sold
'85 944na, -- Sold
Old 02-19-2004, 07:13 PM
The Koni Yellows are the same no matter where they come from, it isnt like someone is selling a "different" Koni Yellow.
1995 BMW 540iA
1987 951 - The Neverending Project
Old 02-19-2004, 07:35 PM
yes i know this, but when the struts come from paragon are they going to already have springs on them and will i need to put srings on them and a housing??
'84 944na -- Sold
'84 944na -- Sold
'85 944na, -- Sold
Old 02-20-2004, 12:34 PM
They are not going to be built, you will need to build them. I am sure they will do it for you but there is a charge for it. AFAIK, you can send them in and they will build them for you. No one is going to sell you complete units.
For an early car you "unscrew" the housing take the old insert out and put the new one in, if you have a big enough set of channel locks it is about a 20 min per side venture.
1995 BMW 540iA
Old 02-21-2004, 05:58 AM
