ReZ ReZ is offline
ReZ's Avatar
Constant RPM *knock knock knock*
When cold, at a constant speed, lets say 1st gear, going 10 mph constant, I hear a knocking. Like a valve knock. As the car warms up, this knock seems to dissapear.
Reving and holding 3K rpms it does it too.
Accelerating and Decel, does not make the knock.
Any ideas? I changed the timing belt over 5K ago, and it seemed to pick this knock up around that time. Maybe it's coincidence.
It's all about the corners!
http://www.calinetworks.net/rez/redt2/7n914pictar.gif
-1985.5 944 (late)
-1974 914
-1990 RX7 TII
Old 02-07-2004, 12:06 AM
SoCal Driver's Avatar
This is coming from the engine?
Does it sound like a thud or a click?
Right now I would suggest looking at the engine mounts. From below the car try to stick your hand in between the oil pan and the cross member just above the steering rack. If you can just get your finger tips in between them then the engine mounts are shot. Should be over an inch of clearance -- most of your hand to the knuckles should slide in there.
If not engine mounts then you may have a crank or rod bearing going out.
Hugh - So Cal 83 944 Driver Person
NOT a 'real' Porsche -- Its Better!!!!
When was the last time you changed your timing and balance belts and/or cam chain and tensioner?
New Users please add your car's year and model to your signature line!
Never break more than you fix!
Old 02-07-2004, 06:02 AM
ReZ ReZ is offline
ReZ's Avatar
It's not the motor mounts. I'll double check, but it does not sound like a thud. It has a knock, kinda like a diesel does, but its only momentarily when at constant RPM. I guess the constant RPM would create a harmonic to make this tinny knock. It sounds exactly like a car would when you are stalling it. KNOCK KNOCK KNOCK!!!!!!
The engine runs strong. I drive the canyons daily, and it sees 3-4K RPMS alot. Sometime it gets up there to 5K. But on street driving, I usually stay below 3800 or so...
As I mentioned before, the knocking seems to go away when it's fully warm. And, it only occurs when the 944 is at constant RPM. IE: 3,200.....
Perhaps when the car warms up, the bearing slack dissaprears... I think the crank/rod bearing is a good guess though. How long until she blows up? It's been doing this for 6 months!
Ty
-1985.5 944 (late)
-1974 914
-1990 RX7 TII
Old 02-09-2004, 07:12 PM
Send a message via AIM to TheCooler
Lifters. I got the same problem. Try the ATF trick. Put a quart in before u change ur oil then drive it around for a day then empty her out and put some fresh oil in. See if that fixes it.
Also get car stethoscope and put it on the valve cover and see if its coming from there. Is the sound louder at around 2 rpms in 5th gear when u floor it? Roll down ur windows and listen to it.
-2002.5 GTI VR6 24V 6SPD
-Kalahari Beige 89 Porsche 944S2
-87 VW GTI 1.8 16v
-2007 Ford PIMP(free)star ...company car....
-1999.5 Jetta VR6
Old 02-09-2004, 09:06 PM
ReZ ReZ is offline
ReZ's Avatar
What the hell? ATF? lol
I thought that only worked on rotaries to get rid of carbon build up! LOL!
I'll try it tomorrow @ 2K in 5th gear when cold. Did the ATF work for you? It's not bad to drive it like this is it?
-1985.5 944 (late)
-1974 914
-1990 RX7 TII
Old 02-09-2004, 09:47 PM
ReZ ReZ is offline
ReZ's Avatar
I'm going to vieotape it so you can hear it tomorrow.
-1985.5 944 (late)
-1974 914
-1990 RX7 TII
Old 02-09-2004, 09:53 PM
Good! I think this is an often overlooked tool for sharing problems here -- audio recording.
Just post/link to the audio part.
Old 02-10-2004, 06:04 AM
ae1969's Avatar
Send a message via ICQ to ae1969
That would be a good idea for a website... audio/video components of 944 repair....
...belt whine
...CV clunking... (hate to be the guy hanging over the side of the car)...
...lifter knock....
...how it runs with intake leak ... etc..
It would be a nice diagnostic tool for new guys....
P.S and how long you can run with a rod knock.... augggh fix it before you have to deal with a spun rod....
Alex - PCA Polar Region - Boxster Muncher
86' 944 Turbo - Megasquirt - 326 rwhp/340lbft @ 18 psi SOLD
www.edmontonhomelife.com
www.edmontonrealestate.ws
Old 02-10-2004, 08:02 AM
ATF = auto transmission fluid, right?
i think im having the same problem
991.1 RS - Lava Orange
991.1 GT3 - Sapphire Blue - gone
997.2 GT3 - Guards Red - gone
996 GT3 4 Liter - Basalt Black - gone
Old 02-10-2004, 03:17 PM
Burn the fire.
Brando's Avatar
it may be a lifter, as my 944 had the same issue. I bought a quart of this wierd lifter-fixer stuff (high-weight gear oil i'm guessing) and it took the noise away after about 20 minutes. ATF should do the trick, that or replacing your lifters.
[x] Working | [_] Broken: 2017 Victory Octane
[x] Working | [_] Broken: 2005 Ram 1500 SLT w/5.7L Hemi
"Drive it like you stole it."
Old 02-10-2004, 05:18 PM
a mechanic i know recommended diesel fuel instead of ATF, any comments?
Old 02-10-2004, 06:15 PM
Zero10's Avatar
Send a message via ICQ to Zero10
Umm yes, don't.
It just doesn't seem like a good idea.
It is probably much cheaper, but I think it would add to the build-up of tar and such in your oil system.
ATF has many detergents, it should clean up the engine while it's in there.
2010 Hyundai Elantra Touring, GLS 5 speed, Indigo Blue Metallic. 2.0L of Korean fury!
Buy my parts!
Old 02-10-2004, 06:43 PM
ReZ ReZ is offline
ReZ's Avatar
Bah. I didn't have time today. I'll see about tomorrow.
-1985.5 944 (late)
-1974 914
-1990 RX7 TII
Old 02-11-2004, 12:49 AM
Rez, I agree with the ATF trick but I've got a feeling that your timing belt is too loose, especially if you have 5K miles on it without re-tensioning it. It doesn't really make sense but the belt slaps the side of the timing belt cover until it's warmed up. Take the upper cover off and take a look at the cover and feel the tension of the belt. If you can turn the waterpump pulley by hand, it's too loose.
Old 02-12-2004, 10:58 AM
BTW: in regards to the rod knock worries, they usually get louder when the engine warms up, not quieter due to the oil thinning.
Old 02-12-2004, 11:11 AM
FLA944's Avatar
Send a message via AIM to FLA944 Send a message via Yahoo to FLA944
1.) Adjust belt tensions
2.) I have had alot of success de-gumming an engine by adding 1 can of "marvel mystery Oil" to the crank and running for 1000 miles then change the oil and use a good synthetic oil and a good oilfilter "mahle".
Rick
'83 944 "Guards Red"
New Everything (seems like)
16" 968 Wheels
has never left garage (yet)
Old 02-12-2004, 02:03 PM
ReZ ReZ is offline
ReZ's Avatar
Here is the knock noise in .ASF
If you can't get it to work, update your CODECs. My Panasonic MiniDV automatically coverts to ASF/ASX.
Right click, save as!
http://www.calinetworks.net/rez/944/944 engine nailing.ASF
All input is good. I think I might try the ATF trick you guys keep talking about. You can't miss the nailing. Notice how I constantly hold RPM when it knocks.
-1985.5 944 (late)
-1974 914
-1990 RX7 TII
Old 02-16-2004, 01:38 PM
look at your oil pressure!
Old 02-16-2004, 03:07 PM
how's your oil level?
Old 02-16-2004, 03:13 PM
ReZ ReZ is offline
ReZ's Avatar
Oil pressure gauge does not work. It stopped working over a year ago!
Start flaming me for driving without an oil pressure gauge!
I think it's a loose connection somewhere in the wire. It worked one day this year, then stopped all of a sudden again!
Oil level is fine. I always check my oil at least once a week. I always check it when I fill up with gas. I do lots of driving.
Anyone know where the oil pressure sender is? I don't have a 944 manuel. I've always wanted to know where though. I bet the contact is dirty.
I'm going to check the belt tension. That could be a very valid problem.
-1985.5 944 (late)
-1974 914
-1990 RX7 TII
Old 02-17-2004, 01:29 AM
