Post What are your results after modding your 944's?
I'm sure this topic has come up before, but I haven't been able to find it, and I'm new.
I've noticed 944's 0-60 times range anywhere from 8.3s to 9.0.
I was told its too much effort to install a turbo, so if you guys could please post your 0-60/ quarter mile times after modifications it would be helpful(and cost involved too).
Thanks.
Old 10-20-2001, 06:32 PM
Rollins's Avatar
Send a message via ICQ to Rollins Send a message via AIM to Rollins
Post
There was a kid here a few weeks ago named Craig. He had a bursch exhaust (I believe), better ignition wires, and some other little stuff, like special paint that made his car 100lbs lighter (or so he said). He was claiming to get something like 6.8 0-60. As has been mentioned before, weight reduction is a big factor. There are not many options in terms of bolt on power. If you REALLY want a 0-60 car or 1/4 mile car then you need a turbo, or to do the Chevy converstion. They can get you a lot of HP. There is a guy named PCM something or other who seems to hang out on the 951 board. He is building a turbo charged car from an NA. He might be able to give you a little more input there. He is quite adamant that this is a good way to go.
Old 10-20-2001, 07:05 PM
JB2 JB2 is offline
Post
QT MILE 15.4@87MPH, CARLSBAD RACEWAY,CA.
MSD 6A,JACOBS WIRES,BOSCH 15V COIL,+4'S,THROTTLE RESPONCE CAM,CUSTOM COLD AIR INTAKE,K&N FILTER,BURSCHE HEADERS,2 1/4 PIPING,HIGH FLOW CAT,FLOWMASTER 3 CHAMBER, TURBO FRONT END,MOMO STEERING WHEEL,STRUT BRACE,KYB'S,MOROSO BATT. BOX AND CUT OFF SWITCH,KENWOOD CD,AUTOMETER TACH AND OIL PRESS GAUGE,SUMMIT DATA RECALL SYSTEM,FALKEN TIRES,EPSILON TWO PIECE RIMS.
Old 10-20-2001, 08:09 PM
JB2 JB2 is offline
Post
OH YEAH, MY WEIGHT IS 2620 WITH HALF TANK OF GAS. NO A/C,PM,PL,SUNROOF,TIRE,TOOLS,JACK,REAR CARPET,AND BACK SEAT.(ALL REMOVED) 1984 944 EURO
Old 10-20-2001, 08:13 PM
Post
WOW that is alot of stuff just to shave off about a second off the 1/4 mile. Just out of curiosity how much did all that stuff run you all together?
Old 10-20-2001, 08:21 PM
