ceris's Avatar
Send a message via AIM to ceris
Headlights
Hi all, I have a quick question about the headlights on my '89 944.
I just bought the car and without the owners manual, most of it is a
mystery.
The alarm is slightly bonkers, the last owner didnt have the key
lockpad, so I dont know exactly how it works. Anyhow, when you turn
the lights off, they flip up and down as if the alarm has gone off
and the only way to make them stop is to put a finger on the light
as it goes down and it wont come back up. I dont like doing this.
Not only is it a pain in the ass, but it is probably not very good
for the lights. Also, when the lights are on, they intially flip up
all the way, and then settle slightly lower, which impairs my
driving ability at night because the lights are not fully shining on
the road. Any advice on repairing this irritating problem would be
appreciated.
Ceris
Old 02-24-2004, 12:29 AM
Sabyre's Avatar
Sounds like a relay. The stock alarm on mine does not move the lights when it sounds.
"We are the music makers and we are the dreamers of the dreams" -Willy Wonka
Old 02-24-2004, 06:54 AM
Feelin' Solexy
Tishabet's Avatar
Is it an 89 NA? Cuz they are the SHIZZ!
Grant
In the stable: 1938 Buick Special model 41, 1963 Solex 2200, 1973 Vespa Primavera 125, 1974 Vespa Rally 200, 1986 VW Vanagon Syncro Westfalia, 1989 VW Doka Tristar, 1995 Toyota Land Cruiser, 2011 Pursuit 315 OS, 2022 Tesla Y
Gone but not forgotten: 1973 VW Beetle, 1989 Porsche 944, 2008 R56 Mini Cooper S
Old 02-24-2004, 07:07 AM
Zero10's Avatar
Send a message via ICQ to Zero10
It sounds like a sensor issue on the headlights.
If I recall correctly, there are 2 switches inside the headlight motor, so it knows when they are all the way up or down, they could be giving you trouble, perhaps the one that says they are all the way down isn't working.
If you turn the knob by hand, after a couple turns, the motor will take over. If the switch(es) aren't working properly, I suppose it could cause the motor to keep cycling the headlights.
It's kind of a guess, but perhaps I am on the right track.
I as well have the issue that my headlights come up then settle back down, and after posting a few times both here and on rennlist, nobody really knew why, so I just adjusted the lights themselves so they would light the road properly.
2010 Hyundai Elantra Touring, GLS 5 speed, Indigo Blue Metallic. 2.0L of Korean fury!
Buy my parts!
Old 02-24-2004, 07:36 AM
SoCal Driver's Avatar
As was just noted there are contacts inside the motor reduction gearing that tell the relay on the motor when to stop/start. These can become corroded. A simple cleaning cures most. Also the relay on the motor can become corroded too.
Should be a rubber cover over the entire motor except for the manual knob and the electrical connector. The connector should have a water tight rubber boot that snaps over the motor. If these are missing or cracked then you must replace them. Especially in a wet climate like Oregon. Take care while turning the manual knob. The motor will cycle pinching fingers.
Hugh - So Cal 83 944 Driver Person
NOT a 'real' Porsche -- Its Better!!!!
When was the last time you changed your timing and balance belts and/or cam chain and tensioner?
New Users please add your car's year and model to your signature line!
Never break more than you fix!
Old 02-24-2004, 07:50 AM
I think its the relay on the side of the motor, either take it apart and clean it or buy a new one.
Cheers
Lance
89 951 Black/Black
Old 02-24-2004, 05:10 PM
fast924S's Avatar
Send a message via AIM to fast924S
I have a head light motor from a 85 944 if you want it let me know :-)
1986 951, Stock for now.
]87 924S Gaurds red- SOLD after 11 years of ownership
Old 02-24-2004, 06:14 PM
