Kirby2's Avatar
Thumbs up WebCam for 944
Wanted to give a final update on the no-run after Cam install:
1) The end cap that is not supposed to be able to turn because of the cotter key in the cam. Well.....it can spin slightly, and did.
It seems that the rotated end cap caused the rotor to face cylinder 3 instead of number 1 at TDC.
No harm to the valves because the cam and the flywheel were in perfect syncro, just the hub that carries the rotor turned.
2) Once everything was put right, the cam is magnificent!! This should be a possible upgrade for every N/A. The sound is inspiring, just a little bit aggressive and it spins up nicely.
3) One of the Porsche should have been items:
An alignment mark on the cam sprocket to verify the rotor or
end cap placement.
03 Silver PT Turbo - Ours
86 White 951 - His
86 White 944 Manual - Hers
98 C-4 Sons
86 Gold 944 Auto - Sons
84 Maroon 944 Auto - salvaged
78 Yellow 924 - found a new home
Old 02-29-2004, 06:25 PM
lousailor's Avatar
Send a message via AIM to lousailor Send a message via Yahoo to lousailor
Glad it woprked out. Any chance you'll be able to get a Dyno or timed run soon?
Louie
'85 (Early) 944 - Beater
'87 924S - Crunch/Rebuild
'76 924 - Long Gone
"If everything seems under control, you're just not going fast enough."
- Mario Andretti
Old 02-29-2004, 08:28 PM
ae1969's Avatar
Send a message via ICQ to ae1969
Uhmmm I thought on the stock cam.... it only can fit one way?
Alex - PCA Polar Region - Boxster Muncher
86' 944 Turbo - Megasquirt - 326 rwhp/340lbft @ 18 psi SOLD
www.edmontonhomelife.com
www.edmontonrealestate.ws
Old 02-29-2004, 08:44 PM
justin's Avatar
Thought about doing this myself,If you don't mind telling us, how much did it cost for everything? Which cam did you get?
Texas hosts the 928 Owner’s Club OCIC in 2009
www.928ocicdfw09.com
1980 928 5 speed and a few mods..........
928 OC member
PCA member
Old 03-01-2004, 12:11 AM
Kirby2's Avatar
Other than this little mixup, this is a relatively easy upgrade. The cam was Webcam grind #274 (.480x254X234). It lists for $440 but you may be able to get a discount at your favorite porsche shop.
Other cost: timing belts if you are close on your 40K cycle, assembly lube (Web sends a small tube), and a new cam gasket, and cam oil seal.
You may want to invest in a good set of long allen wrenches for the cam carrier (have an easyout ready for the allen bolts that you strip out).
Other than my little challenge with the timing key (not webcam's fault), I am extremely happy with the cam! This is a nice Saturday afternoon project!
86 White 951 - His
98 C-4 Sons
Old 03-01-2004, 08:07 AM
MrPants's Avatar
do you happen to know the specs on a stock n/a cam? i haven't been able to find that info anywhere
84 944 Non Alcoholic
Old 03-01-2004, 01:42 PM
bryanthompson's Avatar
Send a message via ICQ to bryanthompson
Dang, I saw the topic and thought 'cool 944 voyeur webcam'
alas, it turns out... i'm a total dork
1983 944 - Sable Brown Metallic / Saratoga / LSD : IceShark Light Kit
Old 03-01-2004, 04:54 PM
lousailor's Avatar
Haw Har Har. FOTGLMAO!!
Louie
'76 924 - Long Gone
- Mario Andretti
Old 03-01-2004, 07:45 PM
Cool idea! Had to find out about it Too, my NA could use a bigger breath!
Here's the link to Webcam http://www.webcamshafts.com/whatauto.html
Anymore info on the improvement may help get it by the kitchen gaurd.
Old 03-01-2004, 08:16 PM
Kirby2's Avatar
actually my wife likes the sound....less rice. The best thing is the ease of install, only a few hours. Money spent always is much less painful when it is in or on the car quickly, and is much easier to explain by going for a spin in a sportier ride.
86 White 951 - His
98 C-4 Sons
Old 03-02-2004, 07:33 AM
