Question Tie Rods???
If your tie rods end have worn rubber bushings, is it necessary to replace the whole end or can just the bushing be replaced? Where can I get just the bushings? Would a worn bushing cause a vibration in the steering wheel when turning or switching lanes at highway speeds?
Thanks.
Joe
Old 10-28-2001, 02:39 PM
AFJuvat's Avatar
Post
Yes, worn tie rods will cause vibration and as far as I know, no, you can't just replace the bushings, though tie rod ends are not all that expensive.
AFJuvat
Old 10-28-2001, 04:02 PM
Post
Who carries tie rod ends for a reasonable price?
Old 10-28-2001, 04:09 PM
Post
Outer tie rods cost ~$35 per side.
The whole "kit" inner and outer is ~$85 if you ask for 944 parts. When i got my -85 944 it needed both inner and outer on both sides. I got one at $75 but was told there was a national back order on more. So the car sat for three months waiting. I got pissed and installed one side drove up to the local forien auto parts place and said i need a inner for a rabbit. The guy said i show three. I said i'm not sure so he got the two he had on the shelf and dam if I got one for $22 that was ~1/8 shorter, it still had over one inch inside the outer rod.
I kept the box will post number tues.
44
Old 10-29-2001, 08:38 AM
