Writer/Teacher
Assuming that the struts come in from Pelican before then, my car will be going into the shop on Wednesday for the following repairs and modifications:
Replace oil cooler seals, flush system Correct steering problem (probably gear slipping, rack needing to be tightened... hopefully not steering rod) Install new shocks (Bilstien Sport) and springs (200lb Weltmeister) Stock rear lowering "trick" Alignment I can't wait to get the the car back!!!! It will ride 1.25 in. lower in front and .75 inches lower in rear... and will (I hope) handle even better. Once I invest in swaybars and the FRwilk chip, I think I will have a pretty good setup in my car
Current Stable: Black 07 Porsche 987 Cayman S: Long-Tube Headers; FabSpeed Exhaust; VividRacing ECU Tune; IPD Plenum; 997GT3 Throttle Body. Blue 1983 Porsche 928S. 1985.5 Porsche 944 Rat Rod. 2011 Acura MDX. 2008 Mazda 3. Gone But Not Forgotten:Garnet Red 86 Porsche 951("The Purple Pig"). Alpine White 83 Porsche 944 ("Alpine Wolf"). Guards Red 84 Porsche 944. |
tell me how it goes with the eccentric lowering trick in the back, i am planning on doing this exact same thing, and also changing my springs in the front, let me know how you like it, good luck!
'84 944na -- Sold '84 944na -- Sold '85 944na, -- Sold |
Dog-faced pony soldier
Sounds cool - I was looking at the Biltstein setup too; let me know how it handles!
A car, a 911, a motorbike and a few surfboards Black Cars Matter |
entertaining the idea
I have the Bilsteins now, installed last year. I think they are great, the car handles awesome.
There are some who call me... 'Tim'. a well set-up 1983 Guards Red 944 |
Yeah, that does sound cool! Keep us posted...
How hard/easy in the rear lowering trick?
Auto Free Finders "peoples marketplace" better value then dealers! |
Writer/Teacher
bilsteins came in today! just a few more days to go!
I am not looking forward to the bill, but I think it's worth it
CJ,
Make sure you give us the follow-up. I'm in work on the same stuff, but with the front Koni inserts. I also just swapped in a 24mm front and a 18mm rear anti-sway bar set-up in conjuntion with new tires, and can definitley feel the diff. If you can find them cheap used, you'll definitely be riding rails with the rest of your set-up.
Louie '85 (Early) 944 - Beater '87 924S - Crunch/Rebuild '76 924 - Long Gone "If everything seems under control, you're just not going fast enough." - Mario Andretti |
Writer/Teacher
lou, yeah that sounds like a good idea... i think i might go even stiffer tho... 22 rear, 29 front i think
![]() after this, my to-do list reads (in this order): New tires FRWilk chip sway bars/bushings strut tower brace
Writer/Teacher
DONE!!!!
What a difference! The steering obviously needed to be repaired, and it handles like a dream now... can't wait for a dry day to really open her up (it rained this morning). I probably won't notice the difference with the new struts and springs until I dive into some of my favorite roads... but I'll let you know how it feels. So far it was money well-spent! And the way the wheels fill out the wheel arches now looks great!
*jealous*
Conrats!
83 944 white w/Boxster wheels Planned mods- custom leather interior, 968 antenna, soundsystem, 968 style rockers, clear sidemarkers
CJ...let's put the camera where the mouth is...pics, pics, pics
87na guards red(mine) 98 suburban(mine) 04 4Runner(wife's) |
Writer/Teacher
no problem... except I have no idea where the digital camera ran off to.
I'll try to get the pics up tomorrow. I think I'll wash the car to celebrate (if it is supposed to be dry tomorrow) Also, check out the changes to the sig
What would Darth Vader do
CJ
Dont forget to ask how to do a turbo mod or how to drop a chevy 8 into your car!! (ducking)
1983 944 (2002 to now) 3-924's (Sold) 1967-912 (Traded) NEVER put a used water pump in your car... |
meister member
I wish that someone had one of those G-Tech performance computers that measures G force while cornering so we could SEE a numerical difference from the old set up to the new Weltmeister set up.
1983 944 guards red with 16" Fuchs, Host of Wisconsin area timing/ balance shaft belt tensioning party 1987 944S Purchased from Legion. Corvette LT-1 V-8 conversion with Mega Squirt II Check on progress ---> www.porschehybrids.com/gallery/speedracing944 Favorite Road = www.tailofthedragon.com 318 turns in 11 miles (11 min 20 sec best run) |
Yep, that would be a pretty cool idea!
Writer/Teacher
well don't forget that my old setup was nearly 21 years old... so it's not like we'd be checking the Weltmeister springs/Bilstein struts against the NEW stock items.
I got around to opening her up late last night (it was pretty dry), and I am very impressed. No dive into sharp turns, no body roll into sweeping turns - the car just stayed level. I'm not going to push my luck because I need new tires pretty soon, but even while taking it easy, the difference was noticable.
