Does anyone have any advice (words of wisdon) on replacing a watter pump on my '83\944. I'm looking to do it myself, is this a difficult thing? (I will have to replace the timing belt)..... sao thats another factor that makes me a lil nervous.
Thanks! Adam |
Feelin' Solexy
I did it a few weeks back, wasn't so bad. Check out clarks-garage.com for a good how to section under "garage manual."
What part of boston are you in? there are a few other bostonians around here....I live in Lexington and work in Cambridge.
Grant In the stable: 1938 Buick Special model 41, 1963 Solex 2200, 1973 Vespa Primavera 125, 1974 Vespa Rally 200, 1986 VW Vanagon Syncro Westfalia, 1989 VW Doka Tristar, 2011 Pursuit 315 OS, 2022 Tesla Y Gone but not forgotten: 1973 VW Beetle, 1989 Porsche 944, 2008 R56 Mini Cooper S |
Thank you Tshabet..!! I read through the instructions. I guess if you can replace this pump, man.. you can do just about anything to your car! Is it really as bad as this sounds? I mean.. I'm good up until the point where they tell you to start taking off sprokets and pullys then its all downhill from there.
I would say from easy to hard.. this is an 8 out of 10. thoughts? I used to live just outside of Quincy when I joined this group. Since then I've moved to the Gardner area and work in Maynard. |
