Rear Main Seal
I've already ruined 2. Can anyone give me a tip on how to install one properly? Oh, and the bearings in the fork, can I get them out and put new ones in, or do I need a press?
'86na, 5-spd, turbo front brakes, bad paint, poor turbo nose bolt-on, early sunroof switch set-up that doesn't work.
Malo periculosam, libertatem quam quietam servitutem.
Old 03-14-2004, 12:41 PM
AFJuvat's Avatar
It's pretty easy once you get the kinks worked out.
1: Make sure the sealing surfaces are spotlessly clean - go in with a razor blade and scrape any crap off.
2: Lubricate the seals with oil - I put some on the inner and outer faces of the seal.
3: You can drive it in with the porsche special tool, which costs around $150, or, you can drive it in using a small block of wood (a 2 x 2 x 4 works perfectly) Drive the seal in flush with the engine case.
AFJuvat
Es geht nicht darum wie schnell man faehrt, sondern wie gut man schnell fahren kann.
Ihr Brunnen der nutzlosen Porsche Information
Old 03-14-2004, 06:50 PM
