pokey's Avatar
Send a message via AIM to pokey
Anyone in socal... HELP!
I'm in Wilmington (I know it's the barrio, but I can live on my tiny sailboat cheap) and am trying to get my 924s running (I bought it with a busted timing belt, and got it all together), everything seems to work the way it should, but it still won't start. If any of you guys could help I'd be eternally gratefull! I'm so frustrated !
Still looking for the right deal on another P-car
1968 BMW 1600 2 liter
1956 Ford F250
1955 BMW R69
1999 Range Rover Callaway #011 of 220 (Yeah, as in Callaway Corvette...)
Old 03-13-2004, 01:58 AM
least common denominator
scottmandue's Avatar
I wish I could help but I'm a mechanical moron...
First questions, you bought it with a broken timing belt?
924S?
2.5 liter engine?
If so valves typically get bent when belt goes bye bye.
Gary Fisher 29er
2019 Kia Stinger 2.0t gone
1995 Miata Sold
1984 944 Sold
Old 03-13-2004, 08:12 AM
SoCal Driver's Avatar
Did you replace the bent valves?
Are the two sensor wires reversed?
Do you have the spark plug cables plugged in correctly?
Hugh - So Cal 83 944 Driver Person
NOT a 'real' Porsche -- Its Better!!!!
When was the last time you changed your timing and balance belts and/or cam chain and tensioner?
New Users please add your car's year and model to your signature line!
Never break more than you fix!
Old 03-13-2004, 09:20 AM
pokey's Avatar
It ate all of the exhaust valves. I've tried the sensors in both positions, Double checked the plug wires. The injectors are firing, the fuel pump is running, getting spark, I'm baffled.
1956 Ford F250
1955 BMW R69
Old 03-13-2004, 12:04 PM
Dog-faced pony soldier
Porsche-O-Phile's Avatar
Where are you located? I'm right over on Ocean Boulevard; maybe I can come over and look at it with you later today or tomorrow. . .
You've checked that everything is in the proper position timing-wise I'm assuming (right?) So the valves are open / closed at the proper time and the spark is occuring at the correct time?
If you're getting air + fuel + spark, there's no reason it shouldn't start.
Black Cars Matter
Old 03-13-2004, 01:42 PM
