-   -   Valve Float (http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/153192-valve-float.html)
Porsche-O-Phile 03-12-2004 04:23 PM
Valve Float
I was reading about a post the other day about someone that redlined their tach and was afraid they might have "floated" the valves. What does this mean exactly? I'm unfamiliar with the term. Thanks!
Roger Hall 03-12-2004 05:00 PM
The cam is turning so fast that the valve springs are not allowed to fully close the valves.
speedracing944 03-12-2004 06:33 PM
If the springs don't close the valves don't worry the pistons will!
Porsche-O-Phile 03-12-2004 07:01 PM
Thanks, makes sense. . . what would be the best prevention for that (besides running the engine at a lower rpm) - stronger return springs?
Zero10 03-12-2004 07:57 PM
Both stronger return springs, and solid lifters.
Not a good upgrade for the average racer.
The heads and manifolds don't flow well enough to warrant revving past 7000, which is where the valves will start floating.
You would see more power by upshifting than letting it rev up.
Roger Hall 03-12-2004 08:39 PM
Typically valve float will not cause you to bend a valve. It can happen but that usually requires more than just redlining the engine. If you reach the RPM's necessary to blow the motor it probably wont matter wich parts exploded.
Alot of people will upgrade springs when rebuilding the head or installing a cam. The power band on your car is below 7000 RPS's though. So the best thing to do is to shift inside the power band.
ae1969 03-12-2004 09:59 PM
The only problem with stronger springs is that the stock hydraulic lifter were not designed for them so then you can have another problem which would cause the lifter to collapse......
Now you see why porsche left the red-line where it is.
rammstein 03-12-2004 10:19 PM
oops.
scottmandue 03-13-2004 08:19 AM
Thanks Roger, gee you learn something every day... I guess I can go back to bed now!
Shift in the power band? Now where is the fun in that!
Brando 03-13-2004 10:44 AM
Just keep it under 7 grand and you can have all the fun in the world.
scheistermeiste 03-13-2004 12:37 PM
hehe rx7 doesnt have valve float....
scottmandue 03-13-2004 03:21 PM
Re: Valve Float
Two scoops vanilla ice cream, add valves and root beer..
Sorry couldn't resist.
