Dog-faced pony soldier
Porsche-O-Phile's Avatar
Valve Float
I was reading about a post the other day about someone that redlined their tach and was afraid they might have "floated" the valves. What does this mean exactly? I'm unfamiliar with the term. Thanks!
Black Cars Matter
Old 03-12-2004, 04:23 PM
Roger Hall's Avatar
The cam is turning so fast that the valve springs are not allowed to fully close the valves.
Roger Hall
81 924 N/A
Some people are like Slinkies. Not really good for anything, but you
still can't help but smile when you see one tumble down the stairs.
Old 03-12-2004, 05:00 PM
meister member
speedracing944's Avatar
If the springs don't close the valves don't worry the pistons will!
1983 944 guards red with 16" Fuchs, Host of Wisconsin area timing/ balance shaft belt tensioning party
1987 944S Purchased from Legion. Corvette LT-1 V-8 conversion with Mega Squirt II
Check on progress ---> www.porschehybrids.com/gallery/speedracing944
Favorite Road = www.tailofthedragon.com 318 turns in 11 miles (11 min 20 sec best run)
Old 03-12-2004, 06:33 PM
Thanks, makes sense. . . what would be the best prevention for that (besides running the engine at a lower rpm) - stronger return springs?
Black Cars Matter
Old 03-12-2004, 07:01 PM
Zero10's Avatar
Send a message via ICQ to Zero10
Both stronger return springs, and solid lifters.
Not a good upgrade for the average racer.
The heads and manifolds don't flow well enough to warrant revving past 7000, which is where the valves will start floating.
You would see more power by upshifting than letting it rev up.
2010 Hyundai Elantra Touring, GLS 5 speed, Indigo Blue Metallic. 2.0L of Korean fury!
Buy my parts!
Old 03-12-2004, 07:57 PM
Roger Hall's Avatar
Typically valve float will not cause you to bend a valve. It can happen but that usually requires more than just redlining the engine. If you reach the RPM's necessary to blow the motor it probably wont matter wich parts exploded.
Alot of people will upgrade springs when rebuilding the head or installing a cam. The power band on your car is below 7000 RPS's though. So the best thing to do is to shift inside the power band.
Roger Hall
81 924 N/A
Old 03-12-2004, 08:39 PM
ae1969's Avatar
Send a message via ICQ to ae1969
The only problem with stronger springs is that the stock hydraulic lifter were not designed for them so then you can have another problem which would cause the lifter to collapse......
Now you see why porsche left the red-line where it is.
Alex - PCA Polar Region - Boxster Muncher
86' 944 Turbo - Megasquirt - 326 rwhp/340lbft @ 18 psi SOLD
www.edmontonhomelife.com
www.edmontonrealestate.ws
Old 03-12-2004, 09:59 PM
Custom User Title
rammstein's Avatar
oops.
Old 03-12-2004, 10:19 PM
least common denominator
scottmandue's Avatar
Thanks Roger, gee you learn something every day... I guess I can go back to bed now!
Shift in the power band? Now where is the fun in that!
Gary Fisher 29er
2019 Kia Stinger 2.0t gone
1995 Miata Sold
1984 944 Sold
Old 03-13-2004, 08:19 AM
Burn the fire.
Brando's Avatar
Just keep it under 7 grand and you can have all the fun in the world.
[x] Working | [_] Broken: 2017 Victory Octane
[x] Working | [_] Broken: 2005 Ram 1500 SLT w/5.7L Hemi
"Drive it like you stole it."
Old 03-13-2004, 10:44 AM
scheistermeiste's Avatar
Send a message via AIM to scheistermeiste Send a message via Yahoo to scheistermeiste
hehe rx7 doesnt have valve float....
Special Edition 924S 1988 <- SOLD!
Asking if you should replace that timing belt is like asking if you should re-use a condom that may have in hole in it with a hooker.
Old 03-13-2004, 12:37 PM
Re: Valve Float
Two scoops vanilla ice cream, add valves and root beer..
Sorry couldn't resist.
Gary Fisher 29er
1995 Miata Sold
1984 944 Sold
Old 03-13-2004, 03:21 PM
