fast924S's Avatar
Send a message via AIM to fast924S
Exclamation speed sensor on late 85 tranny
OK I was swapping parts from my blown 87 924S tranny to the used 944 tranny. I swapped the mounts and the ****er linkage and I removed the speed sensor from the 944 tranny and put the cap over the hole because my 924S doesnt use this sensor it takes the speed from the left front wheel. Anyway I just want to make sure that I am not hurting anything by removing the sensor. Is there anything I should know?? Is there more to the speed sensor inside the tranny that I should remove?? Thanx
1986 951, Stock for now.
]87 924S Gaurds red- SOLD after 11 years of ownership
Old 03-16-2004, 04:10 PM
85944na's Avatar
Send a message via ICQ to 85944na Send a message via AIM to 85944na
should be fine, I have an S2 tranny in mine and my sensor is on the wheel too
PORSCHE: NOTHING EVEN COMES CLOSE
Early 85 G-red 944na, S2 transmission, Ice Shark grounds, Cibie E-Code lights, turbo rear valance, 924S gauges, Turbo S full power seats, "Porsche" door handles, Enkei Wheels.
95 Infiniti G20 dark red metallic-for sale soon
87 BMW 325ic Bronzit, stock(for now)
Old 03-16-2004, 04:41 PM
fast924S's Avatar
bump
Old 03-17-2004, 08:17 PM
lousailor's Avatar
Send a message via AIM to lousailor Send a message via Yahoo to lousailor
Fast,
I haven't taken a good look at my 924S tranny. Can you mount the speed sensor (is there a cap in the same posit) or do you need an updated tranny case? I'm upgrading the front susp so I won't be able to run my speedo from the left front anymore. If it's plug and play I'd like to buy your used sensor, if not I'm going to have to buy the whole thing I quess.
Louie
'85 (Early) 944 - Beater
'87 924S - Crunch/Rebuild
'76 924 - Long Gone
"If everything seems under control, you're just not going fast enough."
- Mario Andretti
Old 03-17-2004, 09:58 PM
fast924S's Avatar
Yes there is a cap where they speed sensor would go, use a allen socket to take it out, The only thing is I dont know if you can just drop in the speed sensor, First off I dont believe our speedo will run off that sensor, You would have to find a aftermarket on because ours are machincal and the one that uses the speed sensor isnt, Second I dont know if the speed sensor that is on the tranny rides on a gear inside the tranny that needs to be installed or if its already there. But if you can find the answeres to these questions I would gladly sell the sensor to you cheap
Old 03-18-2004, 02:45 PM
