meister member
speedracing944's Avatar
HELP! trying to remove fuel rail and injectors
I am in the process of doing my belts and while I am doing them I figured it would be an excellent time to renew all the seals in the cam housing and the cam housing to head gasket. The problem is I am not sure how hard to pull on the fuel rail to get the injectors out. I have all the bolts removed from the rail, and the fuel supply and return lines are off. The rail wiggles back and forth but I don't want to pull on it hard enough to break the injectors. Any advice? are they usually a pain?
Thank you in advance for your help.
speed
1983 944 guards red with 16" Fuchs, Host of Wisconsin area timing/ balance shaft belt tensioning party
1987 944S Purchased from Legion. Corvette LT-1 V-8 conversion with Mega Squirt II
Check on progress ---> www.porschehybrids.com/gallery/speedracing944
Favorite Road = www.tailofthedragon.com 318 turns in 11 miles (11 min 20 sec best run)
Old 03-16-2004, 03:18 PM
meister member
Well I got it out. How do you clean the injectors? Soak them in gas or kerosene? They are blackened quite a bit along with the hole they sit in.
Thanks.
Old 03-16-2004, 03:34 PM
TCMdocs944's Avatar
The "blackening" is probably part of the seals that has melded with the hole. Carb cleaner on a q-tip works pretty good.
The injectors/rail is hard to pull out....seems like a bit too hard when the seals are old AND when you renew the seals it seems like you have to press "too hard" to seat them. Just keep it straight.
There is an excellent artical by AFjuvat in the tech section of pelican parts that goes over injector cleaning 101.
83 944 white w/Boxster wheels
Planned mods- custom leather interior, 968 antenna, soundsystem, 968 style rockers, clear sidemarkers
Old 03-16-2004, 04:08 PM
TSNAPCRACKLEPOP's Avatar
be sure to use atf as a lubricant on replacement, saves breaking them.
chance favors the prepared mind
1987 944 n/a 5spd. who remembers dial phones?.
'STOP FIXING THINGS ONE STEP BEFORE YOU BREAK SOMETHING ELSE"
Old 03-16-2004, 05:30 PM
meister member
Thanks guys. I will read the article. The seals actually look good. They don't have any knicks or tears in them but I will replace then anyways. I just got the cam assembly off and on the bench. The gasket was totally shot but everything inside looks brand new.
Thnks again for your advice.
Old 03-16-2004, 07:11 PM
Send a message via AIM to shocker1322
Be careful on the q-tip idea. I tried that and dropped one into the intake, ended up pulling it off and cleaning it. But if you are doing the seals, might as well clean the holes when the intake is off.
'87 924S, Hawk HP Plus Pads
Centerforce clutch and pressure plate
968 M030 Front and Rear anti-sway bars
28mm Sway-Away Torsion Bars
275 lb/in hypercoils, adjustable Koni's
Old 03-16-2004, 07:20 PM
Official Sponsor
vital-transform's Avatar
I just did mine yesterday (FISeals) and the new seals and hats did not look at all like the old ones so I double checked the part # several times and even cross referanced a few catalogs to get a pictire online and they are correct even though they look larger than the seals that came off runs like a champ now!
I also found that carb cleaner removes the black paint from the injecters as well - will need to protect them from rust somehow in the future?
1988 - 924S Guards red, auto trans
Old 03-16-2004, 08:24 PM
Custom User Title
rammstein's Avatar
I 2nd the injector seals looking wrong- I went so far as to have pelican send a 2nd set, thinking the one I got must be wrong. Turns out it is fine. See Pics here:
How a fool managedto fix a fuel leak
And I used carb cleaner and q-tips to clean the injector contact points (see my pics, they were quite dirty) and I too must recommend you be careful not to drop them in. I didn't, but it occurred to me that if you did, it would suck.
Why do I have insomnia? WHY!?!?!?
-Ramm
Old 03-16-2004, 11:17 PM
Official Sponsor
there is a 924s listed on ebay right now and the reason e is selling it is a bolt dropped into the intake! some great pics of what happens....Porsche : 924
Old 03-17-2004, 06:18 AM
Official Sponsor
Item number: 2465549747
Old 03-17-2004, 06:21 AM
TCMdocs944's Avatar
Ahhrrrrhhhhhggg....
My 44 eats Q-tips for breakfast!
Sometimes you guys worry too much.
(I guess I worry too little sometimes)
BTW-
If you are that concerned just fill the hole with BB's until it is full so that the Q-tip cannot fall into the cylinder. *
BTWBTW-*Just kidding
Old 03-17-2004, 08:21 AM
bb's?????????????` like blatz beer???????????
Old 03-17-2004, 03:57 PM
TCMdocs944's Avatar
I guess beer would work better than BB's ;-)
Old 03-17-2004, 04:40 PM
