No pulse, no spark-ideas
Car no start - car no have spark, car no have pulse - tried a coil didn't work. I'm looking for a good brain to test, any other possibilities?
DME relay?
dead battery :) check the wiring to and from the coil. is it not sparking after the distributor? Check your voltages everywhere.
possibly your motor is running low on liquid coolant :) just kidding. if you are inquiring about your 911 you might just go ahead and replace the DME, it's $33.75 and i hear the quality of them is about worthless in the first place. |
Battery is good. And yes I can see where you may be confused??? It really is a 944 not the 911. Thanks guys.
Car need DME Relay? Car need ignition Switch?(been heavy hitter lately). Do voltage exist at the coil?
Rick |
Speed/ referance sensors?
i think if the speed sensors were bad (usually not working because they ground out) the engine will turn over - but it won't fire.
is the engine turning over? |
AH-HHAA. Reference sensor plug was loose. Found the wire clip was bent and making an intermittent connection. Fixed. Thanks guys!!:D
| All times are GMT -8. The time now is 02:08 PM. |
