No pulse, no spark-ideas
Car no start - car no have spark, car no have pulse - tried a coil didn't work. I'm looking for a good brain to test, any other possibilities?
Feelin' Solexy
DME relay?
Grant In the stable: 1938 Buick Special model 41, 1963 Solex 2200, 1973 Vespa Primavera 125, 1974 Vespa Rally 200, 1986 VW Vanagon Syncro Westfalia, 1989 VW Doka Tristar, 1995 Toyota Land Cruiser, 2011 Pursuit 315 OS, 2022 Tesla Y Gone but not forgotten: 1973 VW Beetle, 1989 Porsche 944, 2008 R56 Mini Cooper S |
dead battery
check the wiring to and from the coil. is it not sparking after the distributor? Check your voltages everywhere.possibly your motor is running low on liquid coolant just kidding. if you are inquiring about your 911 you might just go ahead and replace the DME, it's $33.75 and i hear the quality of them is about worthless in the first place.
1986 951, India Red. (Mine) - Not For Sale Anymore 1987 944, Alpine White. (Bother's) 2000 Audi A6 2.7 Biturbo Melange (Mom's) |
Battery is good. And yes I can see where you may be confused??? It really is a 944 not the 911. Thanks guys.
Car need DME Relay? Car need ignition Switch?(been heavy hitter lately). Do voltage exist at the coil?
Rick
'83 944 "Guards Red" New Everything (seems like) 16" 968 Wheels has never left garage (yet) |
Speed/ referance sensors?
Still looking for the right deal on another P-car 1968 BMW 1600 2 liter 1956 Ford F250 1955 BMW R69 1999 Range Rover Callaway #011 of 220 (Yeah, as in Callaway Corvette...) |
i think if the speed sensors were bad (usually not working because they ground out) the engine will turn over - but it won't fire.
is the engine turning over?
AH-HHAA. Reference sensor plug was loose. Found the wire clip was bent and making an intermittent connection. Fixed. Thanks guys!!
