Restoring 84 944
Hi, new to the forums.
My family has a friend with an '84 944. About 3 years ago he purchased a new car and the 944 has been sitting around ever since. Now, we've been talking to him, and he says that he doesn't want the car (944) and he'd practically give it to us.
Now, I haven't gotten the car yet, but I was wondering if anyone has dealt with a car like this. What type of problems would you expect to see for a car that hasn't been driven in 3 or 4 years? Would it be work that one could do in house or something that would require a mechanic?
If anyone could give me some insight on this subject that'd be great.
Thanks!
Old 03-28-2004, 03:56 PM
Dog-faced pony soldier
Porsche-O-Phile's Avatar
If he doesn't have documentation on what maintenance has been done recently, I'd expect to change all the "usual" expendable items like the oil & filter, gas, fuel filter, spark plugs, cap, rotor, wires, etc. I would STRONGLY recommend replacing (or at least having checked) the timing and balance shaft belts & rollers (they may have gotten quite brittle in a few years time) and the tires (I know this one from experience).
Worst case is replacement of all the front belts, seals, rollers, tensioners - probably about $2,000 to have it done or about $1,000 for parts & tools to do it yourself. I'd strongly recommend not planning on driving it for a while until all that stuff is done or at least checked out.
Enjoy it! Fixing them is rewarding - it's a labor of love (albeit an expensive one).
Black Cars Matter
Old 03-28-2004, 04:14 PM
scheistermeiste's Avatar
Send a message via AIM to scheistermeiste Send a message via Yahoo to scheistermeiste
and dont ask how to put a turbo on it!!!!
and check the grounds too.
Special Edition 924S 1988 <- SOLD!
Asking if you should replace that timing belt is like asking if you should re-use a condom that may have in hole in it with a hooker.
Old 03-28-2004, 04:55 PM
FLA944's Avatar
Send a message via AIM to FLA944 Send a message via Yahoo to FLA944
Welcome to the board!
Sitting for 3-4years early '44
Cam and balance belts and rollers, front seal kit, waterpump (will be there anyway doing belts and seals) oil cooler seals, Coolent hoses and vacuum lines. Check the tires for cracks
Normal stuff fuel filter,oil filter,air filter, plugs,cap,wires,rotor
If have minimal wrench experience all jobs can be done easily with the shop manual and various hand tools. Oh yeah patience too.
Rick
'83 944 "Guards Red"
New Everything (seems like)
16" 968 Wheels
has never left garage (yet)
Old 03-28-2004, 05:22 PM
entertaining the idea
UconnTim97's Avatar
Welcome to the board...
There are some who call me... 'Tim'.
a well set-up 1983 Guards Red 944
Old 03-28-2004, 05:49 PM
Its really not 1000 in parts...unless you buy the porsche belt tensioner (600 bucks) which i have done a belt change without...and no problems. I might get flamed for this...but you can use the kriket tension tool (which is like 20 bucks) or do it by "touch" (this is what i did, and very risky). Im not recommending the above ways, but they can be effectively used. You can probably buy all the parts for about 300 and do everything yourself. Check ebay, lots of good combo deals.
Enjoy it if you get it!
991.1 RS - Lava Orange
991.1 GT3 - Sapphire Blue - gone
997.2 GT3 - Guards Red - gone
996 GT3 4 Liter - Basalt Black - gone
Old 03-28-2004, 07:22 PM
He's correct - I did base my $1,000 in parts & tools on the 9201 Porsche tool. Personally, I'd use nothing else, but opinions vary on this - the 9201 versus Krikit versus "by feel" debate is one of the more hotly debated ones and that decision is yours to make - good luck whatever you choose!
Black Cars Matter
Old 03-28-2004, 09:59 PM
One more question. Considering the time that it has been sitting around... Is it possible that the gass left in the tank has gone bad, or does that take more time?
Old 03-29-2004, 01:36 PM
FLA944's Avatar
Yes, it is bad. Pump out tank then jack up the rear (chock front wheels) remove the hose at the pump from the tank then pour remaining into container. Reattach hose and replace the filter and the check valve on the end of the pump.
add gas (5 gal) add with gas a bottle of injector cleaner.
Rick
16" 968 Wheels
Old 03-29-2004, 01:53 PM
What would Darth Vader do
Gordon Rankin's Avatar
Send a message via Yahoo to Gordon Rankin
I want to know how I can turbo his car...
(ducking quickly)
Gee, its hot outside..
1983 944 (2002 to now)
3-924's (Sold)
1967-912 (Traded)
NEVER put a used water pump in your car...
Old 03-29-2004, 02:33 PM
Either that or you can get easy access to the tank through the rear hatch - lift up the carpeting and CAREFULLY remove the fire matting that covers the fuel sending unit, remove it and you'll be looking straight down into the tank itself - easy access for a syphon. Just don't forget to put everything back when you're done.
And NO SMOKING!!!
Black Cars Matter
Old 03-29-2004, 08:36 PM
I'll bet the AC compressor (if it has AC) is bad after sitting for years without use. Best case you charge it up and it works. Likely case, the compressor has siezed and/or your AC hoses have sprung a leak.
Also, VERY IMPORTANT, drain-flush-and refill your entire coolant system. If there are any deposits that have formed while sitting (rust/scale) they can break loose and clog your radiator. Change all the hoses and the thermostat. This is all really easy, except for the $#%$^&* thermostat. Get a good set of snap ring pliers (SnapOn) for the thermostat and save yourself aggrivation and knuckle skin.
-Dave-
1969 911/3.0l SC
Old 03-30-2004, 08:46 AM
Are anny of you guys familiar with towing the 944? I've read that the 944 isn't one of U-hauls "authorized" vehicles to tow... but the VW rabbit is?
Old 03-30-2004, 01:16 PM
Flatbed
By Alchemist
3-924's (Sold)
1967-912 (Traded)
Old 03-30-2004, 01:21 PM
Where do you guys suggest buying all of your parts? Best price, etc?
Old 04-01-2004, 07:07 PM
TCMdocs944's Avatar
P E L I C A N.. for everything...
Except the seal "kits" and some tools.
engine builders supply
vertex auto-but they gauge you on the handling and tax.
83 944 white w/Boxster wheels
Planned mods- custom leather interior, 968 antenna, soundsystem, 968 style rockers, clear sidemarkers
Old 04-01-2004, 07:33 PM
least common denominator
scottmandue's Avatar
Where are you located?
Gary Fisher 29er
2019 Kia Stinger 2.0t gone
1995 Miata Sold
1984 944 Sold
Old 04-03-2004, 12:52 PM
MikeCT's Avatar
Send a message via AIM to MikeCT
You might want to check out the coolant for any traces of oil; the oil cooler seals could be going.
1984 944 N/A
1996 Golf Gl
Drive fast. Take chances.
If you can't dazzle them with brilliance, baffle them with bull. - W. C. Fields
Old 04-03-2004, 04:04 PM
About the thermostat...if its bad, dont bother replacing it. In fact, taking a heavy duty screwdriver and forcing it out is good anger relief. The thermostat really isnt that necessary...
Old 04-03-2004, 04:28 PM
IF you are in warmer climates!
3-924's (Sold)
1967-912 (Traded)
Old 04-03-2004, 05:03 PM
