Send a message via AIM to Rob Hogenmiller
Is This Engine Shot (Timing Question)
We'll believe it or not I knew about absolutely nothing before replacing an engine in my buddies 944.
After I got it put back in and about ready to start, my grandpa who has experience in cars, suggested I turn the thing over by hand to make sure nothing was hitting.
I had no idea I could do this. I figured all this was internal. Any how when going to turn the crankshaft. I can only get it to do a 358 degree rotation at the most by playing with the camshaft position.
Shouldn't the engine turn 360 degrees continually (with no belts hooked up)?
I'm wondering if this engine I put in is shot or if it is really crucial to have the camshaft and crankshaft aligned just right. I have set them like they say in the book I believe, but not much luck.
I'm going to reposition them one more time then hook the belt up again and see what I can get.
Old 04-07-2004, 06:15 AM
Feelin' Solexy
Tishabet's Avatar
With no belts hooked up you will always have some of the valves open....this is an interference engine, when you're turning the crank you have GOT to be turning the camshaft at the same time or your pistons will come into contact with the valves. You probably didn't do any damage if you were just turning it by hand, you dodged a bullet!
Grant
In the stable: 1938 Buick Special model 41, 1963 Solex 2200, 1973 Vespa Primavera 125, 1974 Vespa Rally 200, 1986 VW Vanagon Syncro Westfalia, 1989 VW Doka Tristar, 2011 Pursuit 315 OS, 2022 Tesla Y
Gone but not forgotten: 1973 VW Beetle, 1989 Porsche 944, 2008 R56 Mini Cooper S
Old 04-07-2004, 06:40 AM
There is only one way the cam timing should be: the correct way. You must have and understand the manual before working on this car.
The 944 is an inteference engine so if the timing is wrong the pistons will hit the valves. I suggest you seek a professional opinion as it may have a simple to diagnose problem.
From November 2012; Precision Porsche Specialist
Sussex UK, +44 (0)1825-721-205
2001-2012 Gerber Motorsport Inc. 206-352-6911
07.15.06 1996 Ducati 900SP. Suprisingly enough, it's red
08.16.09 1999 Kawasaki ZRX1100. Green.
Old 04-07-2004, 06:41 AM
You need to pull the cam tower, align the timing marks, set the engine to TDC on #1 cylinder, install the cam tower, install and tension the cam and balance shaft belts, and so on.
Surf over to Clarks Garage (http://www.clarks-garage.com) and check out the Garage Shop Manual.
Cliff Hipsher
'87 944 India Red
'86 951 Kalahari Metallic
Old 04-07-2004, 06:51 AM
SoCal Driver's Avatar
You don't have to pull the cam tower to get it back to TDC!
You can turn the engine so that all of the pistons are off of TDC then turn the cam till it lines up then turn the crank till it's at TDC.
Been there done it. Several times.
Hugh - So Cal 83 944 Driver Person
NOT a 'real' Porsche -- Its Better!!!!
When was the last time you changed your timing and balance belts and/or cam chain and tensioner?
New Users please add your car's year and model to your signature line!
Never break more than you fix!
Old 04-07-2004, 08:05 AM
s928s's Avatar
It is always best to crank it over by hand once belts are installed at the propper lines ( better safe then sorry..did that once !! ) . I keep the bent valve on my bench just a reminder to check , double check and check again, and then start . Also when turning it over by hand, and watching the reference mark on the cam gear you must rotate the crank 2x to make sure the marks line back up to TDC. ( the crank spins at 2x the speed of the cam.)
autowerks9
PCA SINCE 1991, REISENTOTER
1982 EURO 928S 320HP MEDIORMETALIC/BURG.
1987 944S- GT3 BODY CONVErSION RED/BLACK( sold )
2003 MERCEDES E500 Sport "Einfarbig"
Old 04-07-2004, 08:18 AM
TCMdocs944's Avatar
Whewhh,
I am sweating just reading this post!
Please get everything lined up as they have said and ONCE THE BELTS ARE ON slowly turn the crank.
I would hate to see you have to do the whole thing over again from the head up.
83 944 white w/Boxster wheels
Planned mods- custom leather interior, 968 antenna, soundsystem, 968 style rockers, clear sidemarkers
Old 04-07-2004, 08:30 AM
You too can join The Order Of the Bent Valve!
Just one of many.
Old 04-07-2004, 08:42 AM
ae1969's Avatar
Send a message via ICQ to ae1969
Me too.....
I keep forgetting to line things up when I bolt it all down....... hehehe
P.S lets assume you are in timing.........uhmm did you remove the plugs to turn her over by hand...... a lot of compression builds up and it makes it difficult to turn the engine....
If you hear ... KLINK.... when you are turning that engine............those are valves hitting the pistons.....
Alex - PCA Polar Region - Boxster Muncher
86' 944 Turbo - Megasquirt - 326 rwhp/340lbft @ 18 psi SOLD
www.edmontonhomelife.com
www.edmontonrealestate.ws
Old 04-07-2004, 09:24 AM
Well I got it all line up and it turns over smooth as many times as I want. However I'm wondering about the belt tension. It's a spring tension setup, 1987. I'm wondering is this adjustable or is it self adjusting. The one I did seems pretty tight. The old engine seems pretty loose although the spring tensioner is slightly different.
Thanks for the help. I'm wondering is this spring tensioner adjustable or not?
Old 04-07-2004, 10:30 AM
The tensioner is set by firstly aligning the crank on TDC and the cam on the notch. Loosen off the two 13mm wrench size nyloc nut and bolt and let the tensioner set itself and then tighten the nut and bolt. Rotate the engine by hand twice and then re-align the marks. Loosen and tighten the fasteners again. The balance shaft belt requires a guage to adjust.
Again, this is not the engine to be working on without correct technical information and knowledge.
Old 04-07-2004, 10:56 AM
URIN 2ND's Avatar
In general, you should be able to twist the middle of the belt about 90 degrees...any more and it's too loose. Not that much and it's probably too tight.
This is just a general belt trick, I haven't had it fail me. Yet.
Sean
'88 Porsche 944
'95 Volvo 940T
Seal Beach, CA, USA
Old 04-07-2004, 01:43 PM
These:
Notice the oblong keyed washer under the bottom bolt. This is an important part of the tensioner.
Old 04-07-2004, 04:17 PM
meister member
speedracing944's Avatar
www.clarksgarage.com
Go there. Its is dedicated to the DIY mechanic. They have lots of "how to's" with great pics and torque values for the 944. I own a haynes manual and didn't open it once when i did my cam tower gaskets and belts. I used clarksgarage.
1983 944 guards red with 16" Fuchs, Host of Wisconsin area timing/ balance shaft belt tensioning party
1987 944S Purchased from Legion. Corvette LT-1 V-8 conversion with Mega Squirt II
Check on progress ---> www.porschehybrids.com/gallery/speedracing944
Favorite Road = www.tailofthedragon.com 318 turns in 11 miles (11 min 20 sec best run)
Old 04-07-2004, 04:29 PM
