-   -   Rebuilding my engine (http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/157698-rebuilding-my-engine.html)
TheCooler 04-09-2004 11:39 AM
Im on my way with dropping it now and I think its time to order parts. So far the tab is $739.50!! This is what Im getting so far.
Head Gasket Set
Main Engine Bearing Set, Std
Crankcase Gasket Set
Rod Nuts (I have bearings already but I need to see if I can trade std in for oversize.)
Front Engine Reseal Kit (should I buy all the rollers and stuff to or just check to see if they are in good condition and no playin the bearings?)
Balance Shaft Belt
Timing Belt
Alternator and A/C Belt
Power Steering Belt
Wrist Pin Bushing
Piston Set, Standard
Mahle Oil Filter
Thermostat
Do i need to get a new Oil pressure relief vavle?? Someone said i needed to get it for the head and in the engine.
What else should i get/need?
SoCal Driver 04-09-2004 11:41 AM
If your engine has the seperate spring and piston oil pressure regulator you should buy the newer one piece unit. A bit expensive but eliminates the sticking that the older ones tend to do.
TheCooler 04-09-2004 01:50 PM
I assume it has the one peice one since its a 89...I hope.
