Brake Replacement
The brake pad sensor in my 1984 944 is on, so I am getting ready to replace the pads. I was wondering if there is anything I should watch out for. I have changed disc brakes before, but not on a Porsche. I plan to change out the brake fluid (Super Blue). I've heard I should not bleed the lines by pumping the brake. Is that true? I use the car in the summer, not for any racing. Any recommendations on brake pads? I have heard mixed reviews on the cross drilled rotors. Any thoughts? I will also replace the sensor.
Any helpful advice will be appreciated!
Runnin'On
1984 Porsche 944
Guards Red
Timing Belt Changed 2004!
Old 04-26-2004, 04:38 PM
SoCal Driver's Avatar
Pads, sensor and fluid with a power bleeder and be on your way. Most rotors don't need to be replaced unless you've let the pads go to the metal and the metal has cut really deep grooves in the rotors.
Hugh - So Cal 83 944 Driver Person
NOT a 'real' Porsche -- Its Better!!!!
When was the last time you changed your timing and balance belts and/or cam chain and tensioner?
New Users please add your car's year and model to your signature line!
Never break more than you fix!
Old 04-26-2004, 05:16 PM
ae1969's Avatar
Send a message via ICQ to ae1969
SOcal what are you using as a power bleeder......
I have always been doing the pump and hold routine.... works... but novelty is wearing off.
I am changing my fluid quite frequently nowadays and the wife is getting tired of pumping ....
Alex - PCA Polar Region - Boxster Muncher
86' 944 Turbo - Megasquirt - 326 rwhp/340lbft @ 18 psi SOLD
www.edmontonhomelife.com
www.edmontonrealestate.ws
Old 04-26-2004, 06:10 PM
Burn the fire.
Brando's Avatar
Just grab a $20 mighty-vac from Harbor Freight.
Saved a ton of work on my bug, my dad's 964, and our 911SC.
[x] Working | [_] Broken: 2017 Victory Octane
[x] Working | [_] Broken: 2005 Ram 1500 SLT w/5.7L Hemi
"Drive it like you stole it."
Old 04-26-2004, 07:26 PM
Most any power bleeder will do.
Old 04-26-2004, 09:33 PM
I wouldn't bother with drilled rotors. I'd install a cooling duct kit before drilled rotors, but if you're not overheating your brakes you don't need either.
I use one of those mighty-vacs, it's slower than having someone on the pedal, but you can do it by yourself just fine.
I really like Ferodo Street pads for everyday and auto-x use, they're pretty inexpensive and have great pedal feel. I believe that Pelican sells them too. They're great for everything but harder lapping use (they are a bit dirty though, but any good pad will be).
I agree w/ Socal driver about not getting your rotors turned unless they're really bad or wobbly (I think many-people disagree though!), -a waste of $$ IMO.
You can also easily delete your pad sensors. If you check your pad wear frequently you really don't need the sensors.
Old 04-27-2004, 10:50 AM
Used & Abused
I built a pressure bleeder using the idea from here:
http://www.bmw-m.net/TechProc/bleeder.htm
Works really fast, just fill the bottle, hook it up, pump it up, crack the line and watch the fluid flow. It works really fast and you don't have to worry about draining the resivoir (I know I spelled that wrong)
83 - 944, daily driver
62 - VW Karmann Ghia, never moving restoration
"Oh Bother," said Pooh, as he chambered another round.
Old 04-27-2004, 01:07 PM
MrPants's Avatar
SOcal I am changing my fluid quite frequently nowadays and the wife is getting tired of pumping ....
you could always do some of the pumping
84 944 Non Alcoholic
Old 04-27-2004, 01:12 PM
