Starter problems. Need Help!
Hello. This is my first time posting on this forum and I hope you guys can help me. I have an '83 Porsche 944. When I brought it out from storage a few weeks ago it wouldn't start, so I jumped it and finally got it to start after trying many times. I let it run for a bit to recharge the battery and then turned it off and tried to restart it. The battery was charged (it's actually a new battery) but I heard absolutely no sound from the starter motor; no clicking or anything. I did a little research and found that the problem was most likely my starter, so I ordered a new one and installed it. Now it is starting just fine when it is connected to my truck with jumper cables, but it won't start on it's own. The battery seems to be charged and I can now hear the starter motor winding, but for some reason it won't engage the engine unless the jumper cables are hooked up. This has me really baffled. Thanks for the help.
-Josh
Old 05-02-2004, 02:52 PM
SoCal Driver's Avatar
Clean the grounds from the back of the engine to the chassis and the anchor point on the chassis for the ground from the battery.
Otherwise you may have a bad ignition switch.
Hugh - So Cal 83 944 Driver Person
NOT a 'real' Porsche -- Its Better!!!!
When was the last time you changed your timing and balance belts and/or cam chain and tensioner?
New Users please add your car's year and model to your signature line!
Never break more than you fix!
Old 05-02-2004, 04:23 PM
Cool, I'll give that a try tomorrow. That makes a lot of sense as to why it would work with the jumper cables hooked up.
-Josh
Old 05-02-2004, 06:41 PM
What type of connector is on the positive cable at the battery?
If it's an after market one that clamps the cable under a metal plate with two bolts you need to replace it and the cable. The cable should be solderd into the connector and the smaller red wires should clamp onto and extension of the clamping bolt.
Old 05-02-2004, 10:10 PM
Feelin' Solexy
Tishabet's Avatar
SoCal is spot on with this one, the starter motor need a certain amount of power to "spin up" the gear that engages the flywheel, sounds like you just don't have enough juice getting to the starter itself.
Grant
In the stable: 1938 Buick Special model 41, 1963 Solex 2200, 1973 Vespa Primavera 125, 1974 Vespa Rally 200, 1986 VW Vanagon Syncro Westfalia, 1989 VW Doka Tristar, 2011 Pursuit 315 OS, 2022 Tesla Y
Gone but not forgotten: 1973 VW Beetle, 1989 Porsche 944, 2008 R56 Mini Cooper S
Old 05-03-2004, 05:31 AM
Resistance Is Futile!
Old 05-03-2004, 08:05 AM
