Politically Incorrect
onZedge's Avatar
How do you chase the threads in the block for the head studs?
I have the correct tap. The problem is, it is too short. I must be missing something because I am not a Machinist. Oh, and the tap that Raceware sells is the same length as the one I have. Is there (yet, another) a tool I get to buy to hold the tap?
Edek
'87 924S
'91 535i
Old 05-20-2008, 02:43 PM
well you could do a couple of things. Find a small 1/4 drive socket that fits the square end of the tap. Get a bottoming tap not a taper tap unless your already using a bottoming tap. Or buy a thread chaser kit or just buy the size you need. It looks sort of like a tap but has grooves up the side to clean, thread chasers won't accidently cut the treads if your not at the right angle like a tap will.
If your really stuck or you screw up the threads completly your going to have to drill it out and Heli Coil it
Old 05-20-2008, 04:08 PM
onZedge's Avatar
I'll just add it to the list...
12-Point 5/16" X 1/4" drive socket and duck tape. $2.59
Edek
'87 924S
'91 535i
Old 05-21-2008, 11:03 AM
