Starter problem
I was hoping someone could help me. I have an 83 944 that I recently did a motor rebuild on. When I tried to start the car the starter turned very slowly than stopped. I tried charging the (new) battery for a while before trying again. When I tried to start the car the starter smoked and went bad. I replaced the starter but the problem has remained.
The starter turns very slow than stops.
I have a new battery and starter and the cables look fine.
Can anybody help me with this problem?
Old 05-15-2004, 02:32 PM
Send a message via AIM to TheCooler
Wait, has the engine been started before?
-2002.5 GTI VR6 24V 6SPD
-Kalahari Beige 89 Porsche 944S2
-87 VW GTI 1.8 16v
-2007 Ford PIMP(free)star ...company car....
-1999.5 Jetta VR6
Old 05-15-2004, 04:03 PM
No, the engine has not been fired up yet. I was just trying to turn it over a few times to get oil pressure.
Old 05-15-2004, 05:01 PM
SoCal Driver's Avatar
It's not the starter. Something is wrong in the engine. How much did you rebuild?
Hugh - So Cal 83 944 Driver Person
NOT a 'real' Porsche -- Its Better!!!!
When was the last time you changed your timing and balance belts and/or cam chain and tensioner?
New Users please add your car's year and model to your signature line!
Never break more than you fix!
Old 05-15-2004, 05:14 PM
It was a complete rebuild. Had to get a new crank and all. Motor turns over just fine when I put a socket and wrench on the front pulley.
I remember this problem from before (back when the car was running). I am thinking it might have something to do with the electrical.
Any Ideas?
Old 05-15-2004, 05:24 PM
the electrical to the starter motor is just fine IF it's burning up the starter.
If you have cheap after market clamp on the cable fittings at the battery these could be causing considerable resistance as they corrode badly.
Take the spark plugs out and see if the starter can crank it.
Old 05-15-2004, 05:49 PM
I removed the spark plugs but no change.
Old 05-15-2004, 06:15 PM
ae1969's Avatar
Send a message via ICQ to ae1969
Get that starter bench tested ...
If you can turn the engine by hand the starter should have no problem turning it over.............
Alex - PCA Polar Region - Boxster Muncher
86' 944 Turbo - Megasquirt - 326 rwhp/340lbft @ 18 psi SOLD
www.edmontonhomelife.com
www.edmontonrealestate.ws
Old 05-15-2004, 08:29 PM
Got the starter to spin up once. But now it went back to its slow rotation. This sounds like some kind of grounding problem.
I replaced both the battery leads.
I bypassed the ignition and got the same symptoms.
I don't know what it could be.
Old 05-15-2004, 10:27 PM
MrPants's Avatar
Have you had the battery tested? sounds like it might be a bit weak, even if it has enough volts. Or you can watch voltage at the battery while someone else is attemptinf to fire it up to see how much the voltage drops.
84 944 Non Alcoholic
Old 05-16-2004, 02:38 AM
Don 944 LA's Avatar
Originally posted by MrPantsHave you had the battery tested? sounds like it might be a bit weak,
Old 05-16-2004, 02:55 AM
The battery is good. I even tried jump-starting and got the same results. Everything has been changed out (wires, starter, battery) but it still will not spin up.
Starter was bench tested.
Could this problem be with the main grounding on the car?
Does anybody have any ideas?
Old 05-16-2004, 05:55 PM
There is supposed to be two or more heavy woven ground wires from the back of the block to the chassis.
Please add your year and model to your signiture.
Old 05-16-2004, 09:22 PM
I found the problem. My grounding from the motor to frame went bad. Fixed it right up with a new ground wire.
Thanks for the help.
04 infiniti G35
Old 05-18-2004, 12:57 AM
Grounds! Why is it always the grounds!
Old 05-18-2004, 09:46 AM
