-   -   source of a click when turning (http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/164496-source-click-when-turning.html)
bryanthompson 05-24-2004 09:27 AM
Last night I noticed that when going through a turn at 25 and up there's a noticable 'click' sound. It only does it once, and seems to be from something shifting weight around the curve. If you set a baseball in the hatch and go around a curve, right when the ball would hit the side while going around a curve is where my sound happens. The sound is coming from the front of a car.
The sound is pretty dense, if that makes sense.
Would bad motor mounts make the sound? Old swaybar bushings or something like that?
bryanthompson 05-24-2004 09:28 AM
Oh yeah, rear CV joints are all in good shape. click when turning automatically makes you think CV joints, but i checked and they're okay. The sound's coming from the front of the car anyway.
mattdavis11 05-24-2004 09:36 AM
Ball joints would be my guess.
bryanthompson 05-24-2004 09:55 AM
i was just reading the ball joint thread which made me want to post this. I'm sure they could use an update. Were ball joints giving you the same sort of sound?
mattdavis11 05-24-2004 10:02 AM
No sound here. I just wanted to work on my car. It can't hurt to have all new stuff up front, ie. bushings, joints, caster plates, etc..
I had a lot of squishy stuff, I'll tell ya that.
bryanthompson 05-24-2004 10:06 AM
I'm sure I'm in the same boat there. Did you do wheel bearings too? I think i might do everything all at once.
mattdavis11 05-24-2004 10:26 AM
I did the wheel bearings a year ago or so, and check them every so often. Struts were also changed awhile back. In hind sight, I'd do it all at once too, but I always seem to choose the hard way vs. the easy.
