rotten eggs
I was told that the rotten egg smell that I get in the cab when excellerating is caused by the mixture being too rich.
The shop drilled out the mixture cap and adjusted the mixture and got it right on according to the 'scope'. I'm still getting the the smell though. Not as bad but is still there.
Any thoughts?
Thanks, Paul
83 944
Old 05-30-2004, 08:20 AM
SoCal Driver's Avatar
You have air leaks in the back of your car. Most likely around the tail lights or the hatch seal or both.
The tail lights are sealed with the 3M black putty like stuff. The hatch seal is either the pin adjustment or the seal or both.
Hugh - So Cal 83 944 Driver Person
NOT a 'real' Porsche -- Its Better!!!!
When was the last time you changed your timing and balance belts and/or cam chain and tensioner?
New Users please add your car's year and model to your signature line!
Never break more than you fix!
Old 05-30-2004, 10:08 AM
I think you nailed it.
I have no hatch seal.
Guess I better order one.
No driver door seal either.
Also, I think I'm missing a boot that goes under the shifter boot.
Air comes up from the shifter. Stinks!
Thanks, Paul
83 944
Old 05-30-2004, 10:17 AM
You have to seal the cab from the exhaust gasses or you will poison yourself, pass out and have a permanent out of body experience.
Old 05-30-2004, 10:44 AM
A new hatch seal will stretch when you put it on. Don't cut the ends short as this will soon result in a gap as the seal shrinks.
Old 05-30-2004, 10:46 AM
SidVicious's Avatar
The only time I had a 944 smell like sulphur the voltage regulator died. I had no choice but to drive home with the gauge pegged, and the battery was toast by the time I got home.
Old 05-30-2004, 11:18 PM
Could have turned on all your lights and played your 10,000 watt stereo at full blast!
Watt? Watt did you say? Watt? You have to yell? Watt?
Old 05-31-2004, 09:00 AM
Dog-faced pony soldier
Porsche-O-Phile's Avatar
And get some of that Wurth rubber sealant stuff; I found it useful to seal up the joint where the two ends come together (in the middle). It's a pretty straightforward installation.
Black Cars Matter
Old 05-31-2004, 10:05 AM
You know, if the sulfur smell is from the exhaust you might want to run a couple cans of Sea Foam through your gas to help clean out the catalytic converter.
Old 06-01-2004, 09:11 AM
Mechanic in a Can.
Worked 50 years ago on that old Chevy of Dad's!
No reason it can't work on a Porsche!
Did they have CATs fifty years ago?
NOT!
Old 06-01-2004, 09:19 AM
TCMdocs944's Avatar
Can't you just spray the SeaFoam in the interior to get rid of the smell? It seems to do everything else.
83 944 white w/Boxster wheels
Planned mods- custom leather interior, 968 antenna, soundsystem, 968 style rockers, clear sidemarkers
Old 06-01-2004, 03:01 PM
