TCMdocs944's Avatar
Question Does this rocker line serve a purpose?
When modifying the 944 rocker panels does this seam serve a purpose or is it just where the front fender can be removed?
83 944 white w/Boxster wheels
Planned mods- custom leather interior, 968 antenna, soundsystem, 968 style rockers, clear sidemarkers
Old 06-08-2004, 10:11 AM
SoCal Driver's Avatar
Front fender.
Hugh - So Cal 83 944 Driver Person
NOT a 'real' Porsche -- Its Better!!!!
When was the last time you changed your timing and balance belts and/or cam chain and tensioner?
New Users please add your car's year and model to your signature line!
Never break more than you fix!
Old 06-08-2004, 11:57 AM
TCMdocs944's Avatar
If I fill it when doing the 968 rocker thing it is no big deal then?
I will assume yes....Thanks.
Old 06-08-2004, 01:57 PM
Filling it will not let you take the fenders off. Also the fenders move independen of the body so most likely any "fill" (bondo) will crack.
Old 06-08-2004, 02:47 PM
pokey's Avatar
Send a message via AIM to pokey
He could weld them, no?
Still looking for the right deal on another P-car
1968 BMW 1600 2 liter
1956 Ford F250
1955 BMW R69
1999 Range Rover Callaway #011 of 220 (Yeah, as in Callaway Corvette...)
Old 06-08-2004, 03:53 PM
Welding will burn the galvanizing off. Will start rusting real bad then.
Old 06-08-2004, 05:00 PM
TCMdocs944's Avatar
Interesting.
The fenders need some movement of their own.....
I was thinking about masking off the 968 area and just spraying more texture coat then paint followed by clear. Just to build it up a little.
Welding never entered my mind BUT, there are ways to clean and prep to avoid rust post weld. Just more extensive than I want to get into.
I will have to consider this more methinks.
Old 06-08-2004, 05:07 PM
