-   -   anybody got advise on installing a H2O temp gauge ? (http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/168350-anybody-got-advise-installing-h2o-temp-gauge.html)
garyC 06-18-2004 02:38 PM
Is it just me or are these cars not real easy to work on ? I'm use to things like 68 -70 Roadrunners, Chargers, Super Bees.
I have a haynes manual for the 924 but most of it still seems greek to me. I don't think they did as good a job on the Porsche manual as they did on the old muscle car manuals . LOL
Anyway, I am not a fan of idiot lights. How difficult is it to install an aftermarket water temp gauge. Oh and where is this coolant flange located ? I assume I have to mess with it to put in a new gauge.The pics in the manual are not that great .
thanks for the input !
Gary
SoCal Driver 06-18-2004 02:54 PM
Don't you have an engine temp gauge in the left instrument cluster?
garyC 06-18-2004 03:54 PM
Its not woking :(
todwic 06-18-2004 04:15 PM
Change the sensor?
SoCal Driver 06-18-2004 04:24 PM
Find the temp sender on the engine, take off the wire and ground it with the key on. See if the gauge moves. If it does replace the sender.
garyC 06-18-2004 04:30 PM
Imwithstupid^ 06-20-2004 07:35 PM
You can install an aftermarket gauges with the stock sender. I have noticed this only to work with the water temperature sender, not the oil pressure or fuel level. In the cluster of all those wires it is the blue/yellow one, not the blue/black like Haynes says. Just repalce the stupid clock with a water temp gauge ;)
I used Dolphin digital gauges so those are the only gauges i can vouch for.
idontknow 06-20-2004 07:57 PM
Ya know, if the sender is bad, installing a new gauge won't help!
Imwithstupid^ 06-20-2004 08:32 PM
Yeah, i forgot to mention that was based on the assumption the sender works of course :)
fred cook 06-21-2004 04:23 AM
Water temperature gauge
After a bad experience with the stock temp. gauge on my 924S, I replaced the clock with a VDO temp. guage. I extended the sender wire across to the console, ran a power lead from a switched source and hooked up a ground wire. For a guage light, I reused the stock light that had been in the clock. Since I really did not trust the sender, I replaced it at the same time. This is a very easy job that will take no more than 1-2 hours.
Good Luck!
Fred Cook
'88 924S (sold)
'80 911SC coupe
garyC 06-24-2004 07:36 PM
thanks!
Guess I'll do the test SoCal recommended and either switch out the sensor or gauge as the case may be.
Looks like a busy day next weekend with needing to replace a thermo switch too !
Thanks again !
