Question anybody got advise on installing a H2O temp gauge ?
Is it just me or are these cars not real easy to work on ? I'm use to things like 68 -70 Roadrunners, Chargers, Super Bees.
I have a haynes manual for the 924 but most of it still seems greek to me. I don't think they did as good a job on the Porsche manual as they did on the old muscle car manuals . LOL
Anyway, I am not a fan of idiot lights. How difficult is it to install an aftermarket water temp gauge. Oh and where is this coolant flange located ? I assume I have to mess with it to put in a new gauge.The pics in the manual are not that great .
thanks for the input !
Gary
1982 924 Turbo
Old 06-18-2004, 02:38 PM
SoCal Driver's Avatar
Don't you have an engine temp gauge in the left instrument cluster?
Hugh - So Cal 83 944 Driver Person
NOT a 'real' Porsche -- Its Better!!!!
When was the last time you changed your timing and balance belts and/or cam chain and tensioner?
New Users please add your car's year and model to your signature line!
Never break more than you fix!
Old 06-18-2004, 02:54 PM
Its not woking
1982 924 Turbo
Old 06-18-2004, 03:54 PM
todwic's Avatar
Send a message via AIM to todwic Send a message via Yahoo to todwic
Change the sensor?
*Disclaimer: The person above is actually dumber than he appears.
my web site Torque values maintainance and repairs lots of my rebuild pics weights and measurements
'84 944 auto/ps/ac/cc
'86 951
Providing ignorance one post at a time.
Old 06-18-2004, 04:15 PM
Find the temp sender on the engine, take off the wire and ground it with the key on. See if the gauge moves. If it does replace the sender.
Old 06-18-2004, 04:24 PM
1982 924 Turbo
Old 06-18-2004, 04:30 PM
You can install an aftermarket gauges with the stock sender. I have noticed this only to work with the water temperature sender, not the oil pressure or fuel level. In the cluster of all those wires it is the blue/yellow one, not the blue/black like Haynes says. Just repalce the stupid clock with a water temp gauge
I used Dolphin digital gauges so those are the only gauges i can vouch for.
1984 Porsche 944 na
Black on Black leather
Digital Dash
Auto dimming rear view mirror
Enkei 15x7's
Fog/headlight mod to come
AIM - ShawnMacAnanny
Old 06-20-2004, 07:35 PM
Used & Abused
Ya know, if the sender is bad, installing a new gauge won't help!
83 - 944, daily driver
62 - VW Karmann Ghia, never moving restoration
"Oh Bother," said Pooh, as he chambered another round.
Old 06-20-2004, 07:57 PM
Yeah, i forgot to mention that was based on the assumption the sender works of course
1984 Porsche 944 na
Digital Dash
Enkei 15x7's
Old 06-20-2004, 08:32 PM
fred cook's Avatar
Cool Water temperature gauge
After a bad experience with the stock temp. gauge on my 924S, I replaced the clock with a VDO temp. guage. I extended the sender wire across to the console, ran a power lead from a switched source and hooked up a ground wire. For a guage light, I reused the stock light that had been in the clock. Since I really did not trust the sender, I replaced it at the same time. This is a very easy job that will take no more than 1-2 hours.
Good Luck!
Fred Cook
'88 924S (sold)
'80 911SC coupe
Old 06-21-2004, 04:23 AM
thanks!
Guess I'll do the test SoCal recommended and either switch out the sensor or gauge as the case may be.
Looks like a busy day next weekend with needing to replace a thermo switch too !
Thanks again !
1982 924 Turbo
Old 06-24-2004, 07:36 PM
