-   -   944 limits ( a few technical questions too) (http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/168613-944-limits-few-technical-questions-too.html)
Imwithstupid^ 06-20-2004 06:34 PM
Hey, i am a rather new 944 owner and in being so i have had the car off the road pretty much ever since i bought it in replacing parts and such. I haven't gotten to test it's limits yet, and i was wondering if anyone has ever 'out-driven' a 944.
When cornering when would it break traction on stock wheels? I did have the pleasure of driving mine for about a week, but i never got to test this too much. I know when cornering very fast and sharp you can hear the tires squeal but they do not feel like they are going to break loose. I was using 215/215's and i am planning on getting 235/245s in hopes of solving the squealing problem.
Has anyone ever rolled one of these? My previous car had electronic suspension which when it would sense a roll over it would stiffen the suspension instantly to break traction and cause you too slide. I plan on upgrading the suspension on these cars and with wider wheels i am afraid of possibly rolling them if i corner too fast since the tires will most likely not break traction.
The suspension feels a bit soft, noticeable body roll compared to a vr4 but very solid to a mustang. I dont know if my parts are worn or it is supposed to be like this. I want to lower the suspension to handle better. I live in DE and ride quality won't be a problem since every highway and major back road is repaved every 1 or 2 years.
Can i adjust the rear supension? I have the rear end jacked up to replace a trailing arm and bearings, and it looks like it's adjustable. Would it hurt for me to adjust this?
What are the limits of the transmissons? Will they break easily, or is it just the clutch that gets ruined?
A really stupid question but one my friend asked me the other day which made me wonder. Has a 944 ever done a wheel stand, turbo or na?
Another stupid question. What will it sound like if i remove the exhaust and run an open cat? My exhaust muffler is really black and chrome, i dont know which it's supposed to be but something is flaking and it looks tacky. I was just going to remove the stock cat even and just run a 3" magnaflow cat then out of side pipes since i am not too sure if i can get rear duals around that gas tank. I just like two pipes because symetry is a big thing to me.
This is a question i just thought of but doesnt have anything to do with limits. I put on an open element filter and there was oil in my stock air box, throttle body (whatever porsche calls it), and intake tract. Is this ok? I know it had full oil and i added some CD2 without draining any so i figured it probably just leaked past the rings or something, but my car has only smoked once. I was peeling out coming out of stop sign on a back road and i shifted into second which gripped up and a cloud of smoke just shot out. It hasnt smoked ever again though.
If there are any limits i am missing please someone add them. I want this to be the do's, don't do's, and how much to do's of the 944.
SoCal Driver 06-20-2004 07:12 PM
Wheel stand. That's funny.
mambodave 06-20-2004 07:30 PM
2 words as far as limits...
DRIVERS EDUCATION
Tires wont do a damn thing if you cant drive.
Ive done DE, and high speed tracking for years....This car still scares the hell out of me sometimes.
Your car is much more capable than you are as a driver. Get some training if your gonna make those tires sqeal.
Join the PCA .
And the stock exhaust setup is just fine.
BTW...If you "Peel Out" on a regular basis, get ready to put in a new tranny.
idontknow 06-20-2004 07:48 PM
It very much depends on tires. I have a set of Comp T/As for daily driving and can squeak tires easily at 40mph in a 10ft radius turn. The set of autoX rubbers on the same turn won't break loose at 55 in the same turn. (never pushed it past that) Be very careful about clearance in the front w/ the 235's, you can shave the rear spacers to fit the rear tires but you might slice the tire using over a 225 in the front.
The 944 has a pretty low center of gravity and I've only heard of one person rolling his 944 off the side of a mountain so yes I guess it's possible.
Umm, loud, very loud.
Oil in the intake tract could mean a lot of things or nothing. i have little experience in this so I'll leave it to someone else.
There's a page floating around showing the various adj bolts and what they do. Do a search and i'm sure you'll find it.
You will destroy the Ring and pinion if you enjoy hard launches. Don't worry cause you almost have to remove the tranny to install a new clutch.
Once again you'll snap the ring and pinion before the front end gets in the air.
Personal comments:
Peeling out at a stopsign = you probably wont blow the tranny as quickly w/ tires that lose grip. Get it out of your system on those tires, then get some grippy tires.
Side pipes don't look tacky? OMG
Your tires will break traction, or you will break suspension. You may wish to invest in a set of sway bars if your car feels unsettling.
Eli K 06-20-2004 07:55 PM
that's a 2" magnaflow cat. 3 would be too big make sure you specify your exact model car, as the universal magnaflows are too big, porsche cat is tiny compare to your average converter...
Imwithstupid^ 06-20-2004 07:59 PM
Yeah the wheel stand thing made me laugh when my friend asked me, but intrgued me nonetheless.
I bought new rims since i needed new rear tires becuase my bearings just snapped and destroyed them. I decided to buy wider ones and put wider tires on them. I bought them for more traction. I have yet to drive it in the rain, but the only RWD i have owned was a mustang and i am a little paranoid with another RWD car. I cant begin remember how many time i have hydroplaned, spun out, and not been able to stop in that thing. (It was a 95 lx-v6) It wasnt my driving that limited that car, that car just didnt want to grip the road for anything.
I would seriously like to get into some road racing or even rally (not with the 944 of course). The 944 has yet to scare me as far as losing control of it, but i will admit i won't push it further because i question my abilities as a driver. I know there was a turn marked for 30mph,, non banked, barely two lanes wide, no shoulders, and open fields on both sides. I live out in the country. This i took at 110 chasing an 03 cobra (which i caught and passed :) ) in my vr4 and that began to scare me becuase i could hear the tires over my straight pipes. Same with the cobra's. I have take this turn at 120, progressively of course, and noticed much more traction in the 944 so i only ask because i know at some point this thing will roll.
I practice my own driving and race conditions out where i live because there is practically no one and the roads are excellent since they just repaved them. I live in Sandtown is anyone is wondering. It's the most rural part of DE. It might sound irresponsible, but it's not too bad. All the roads are visible since there are no hills and just open fields. There are very few cars on these roads ever and if there are you can seem them from a mile or so away.
I know the stock exhaust is fine, it's quiet, but i mine is really worn out, and i hate single side exhaust systems. If it were less noticeable it wouldnt bother me that much but it just sticks way out.
I don't peel out on a regular basis, i was just seeing my my trans was an LSD which i still can't figure out.
I jack it up, spin the wheels they move opposite
I put it in gear and drive it on stands and they both move forward
I peel out it leaves two very distinct, curved (from sideward sliding) tire marks
I go around a turn peeling out and it leaves one tire mark, the inside.
I just dont know
idontknow 06-20-2004 08:05 PM
No LSD, and hey, that's my line!
Imwithstupid^ 06-20-2004 08:13 PM
I havent checked the stock porsche cat, but mine looks like it's atleast 3 feet long. What are these worth if i sell them? Would i be able to sell my muffler as well? I just really like the exhaust systems this guy does so if i do decided to do exhaust work, it will all be doen at once by him.
I have a local muffler shop who has done several exhausts for me. If i were doing exhaust i would install ceramic coated headers at the same time then have him build me a system from the headers back. He uses 14 gauge aluminum pipes which are pretty awsome.
The side pipes wouldnt be like old camaro or corvette side pipes. They would be more like Roush or something. Just the tips visible and be flat, low profile. I just dont think i will be able to fit pipes in the rear by the gas tank.
Also i have to replace my front bumper since the bottom lip is broken off. Any suggestions for different bumpers, if any, or if i should use a turbo one?
Trevor 06-20-2004 09:04 PM
I might be interested in the muffler if it is stock.
Porsche-O-Phile 06-20-2004 09:08 PM
If you want a drag car, get a Mustang or a Corvette. If you want the best handling in the world, good top end speed and adequate acceleration, then your 944 will fit the bill.
These cars are a total joy to drive, but MAKE SURE the maintenance is done. They are NOT forgiving of neglect.
Imwithstupid^ 06-20-2004 09:36 PM
Well which tires will make it better handling? I didnt buy it for a drag car, actually i didnt even buy it for anything other than fuel ecconomy.
Yeah i need to replace the timing belt. Thats just something i do on every used car i buy. This looks alot easier then my previous 24v DOHC Twin Turbo AWD set up.
The last two cars i owned were for performance so i was very meticulous with maintenace.
timing belt as soon as i purchase the car (once year)
hubs/bearings as soon as purchased (every 50k miles)
water and oil pump if not already new (once every two years)
cooling and oil systems flush (every 20k)
20+oz of sea foam in the intake (every 20k)
10+oz of sea foam in the oil (500 miles before every oil change)
entire bottle of sea foam in the gas tank (every 5k)
bleed brake lines (every pad change)
change transaxle fluid (every year)
grease all fittings (every couple oil changes)
air filter (every 15k)
oil and filter change (every 3k)
tire pressure (every weekend)
And a few other things
yes the muffler is stock and the pipe work is in excellent condition. The tip is just discolor or needs to be cleaned/polished.
Eli K 06-21-2004 09:28 AM
For being 17 you sure had a few top notch cars...Wish I had your parents when I was 17
Z-man 06-21-2004 09:48 AM
Please don't do that!
Driving at such high speeds on public roads, no matter how 'barren' they seem is just dangerously stupid.
Try your hand at autocross, or get involved with your Porsche Club region's driver's ed program. (Driver's Ed involves you driving your car on a race track at speed - it ain't your high school driver's ed program for sure! )
Hard launches will most likely kill your CV joints before your tranny or Ring pinion go. CV joints are a little cheaper to replace than trannies and R&P's, but you really want to limit the number of smokey burnouts done with a 944, if you desire to NOT break things! :)
Nevertheless, congrats and welcome to the world of the 944!
-Z-man.
Imwithstupid^ 06-21-2004 10:53 AM
I bought the cars myself with little to no help. My dad bought me my mustang in advance which i paid off in 2 months over the summer it was $2,700. I sold that for $4,300 and bought my VR4 for $3,500. I used the rest of the money for parts and some work. I totalled that car and made enough the first day parting it out to buy my 944. Parts now total over $3k so i have had plenty to fix up the 944. I havent had to borrow or ask for money from my parents since the day i got my mustang.
I would autocross or something but there are no tracks anywhere. There is Dover Downs, the NASCAR track and that's it. There is a drag strip about an hour and a half away, but they are no fun.
Z-man 06-21-2004 12:04 PM
How did you total your VR4? (Just curious....)
In terms of autocross, check with the Delaware region PCA:
http://www.delawarepca.org/
Looks like they autocross with the Brandywine Motorsports Club, but they don't have anything going on in 2004 yet....
Also check SCCA.org and NASA for local autocross happenings.
As far as tracks go, you are within 'striking distance' from a couple of world class tracks: VIR (Virginia Int'l Raceway) and Summit Point in W.VA. Also: Pocono Internation isn't that far either. Plus while still in the planning stages, there is a track they are building in Millville, located in South NJ:
http://www.nj.com/news/bridgeton/index.ssf?/base/news-1/1086168035181600.xml
Do enough digging and you will see there are plenty of motorsport events you can participate in! Saying there are no venues available is a poor excuse to play on public roads.
Glad to hear that the 1/4 mile doesn't interest you!
-Z-man.
Imwithstupid^ 06-21-2004 12:20 PM
i swerved for a dead cat :p wasnt even being stupid. I'm not exactly sure how it happened but i was doing aout 55mph and my friend was following me she said i was stright in the opposite lane for a while then my rear end hopped up and i slid sideways which i held for about 300ft until i hit the ditch which is where i remember from becuase i jerked the wheel left and locked up the wheels to get it to spin. a 3,900lb car isnt something you want directly slamming into anything. i know i had pushed the clutch in when i swerved for the cat, then i took it out of gear when i was sideways and just put my head against the head rest. I have pics 10 minutes after the accident if you want to see any. I was stuck about 3ft in the air between two trees :)
idontknow 06-21-2004 01:29 PM
I'd love to see this!
mambodave 06-21-2004 01:34 PM
That would have been i flat cat if i had been driving!
Pics....you bet
Imwithstupid^ 06-21-2004 02:03 PM
whoever has a cable modem send me their email. I have a 56k so i will send the entier folder (1.7mb winrar) to one person to host or distribute. There are 80+ pics. I have a pic of the cat too. I am kicking it wearing my 70's disco 'fiesta' bell bottoms. They are my lucky pants :) i crawled out of the car without a scratch and car started right back up. of course the transmission bellhousing snapped completely in half and off of the block but it still ran.
AaronM 06-21-2004 03:15 PM
LSD is check-able by the option code listing in the spare tire well. It is option code 220.
Aaron
Imwithstupid^ 06-21-2004 03:32 PM
Nope doesnt say i have one.
c02, 418, 425, 431, 454, 456, 650
456 is a sport option of some sort. What does that mean?
Why do both wheels burnout then? I'm not worried if it isnt an lsd, it spins both on grass, dirt and pavement which is fine with me.
AaronM 06-21-2004 06:02 PM
C02: Catalytic Converter
418: Body Side Molding
425: Rear Window Wiper
431: 363mm Leather Steering Wheel
454: Automatic Speed Control (AKA Cruise Control)
456: Sport Shock Absorbers and Stabilizers
650: Sunroof
Given the nature of these cars (and the relative frailty of the transmissions if the car experiences any hard launches), it's quite possible that someone put an LSD in the transaxle either as an upgrade or to replace a busted differential.
Aaron
Imwithstupid^ 06-21-2004 06:16 PM
My speed control doesnt work so i am assuming that the motor is bad, or could it just have seized up and be worked free? The LSD trans should both spin both wheels in the same direction correct? I can spin them by hand, out of gear, and they spin opposite diretions, but there is absolutley no mistake that they both leave very dark tire marks and cause my car to fish tail when burning out. Is there another test i can perform?
Also, i noticed while my car was jacked up, if i start it up and let it idle and release the clutch in nuetral the wheel will spin. I dont know if they spin opposite because i just have bare axles haning which i dont like to let spin, but should it do that? Also when the tires were on and i left it in nuetral with the clutch out i noticed it made a noise from the rear end. Is this something bad, or is it just the fluid sheering causing the wheels to spin, and the noise in the rear?
nickd 06-21-2004 06:50 PM
There is so much wrong in this post I just can't take it...
#1 You don't have LSD. If you did both wheels would turn the same direction while the car is off the ground. LSD was a fairly rare option. Open diff's can spin both wheels if you're trying to.
#2 Why do you think pipes won't fit around the fuel tank? The stock exhaust seems to fit very well. An open exhaust is just going to loose what little power these cars have to begin with and sound really terrible. Really.
#3 Tires are what make contact with the ground. Width is one thing, compound and design is another. If you want better handling, buy better tires. Z-rated rubber rarely squeels. But, it usually breaks loose much less progressively than less sticky tires.
#4 You won't roll this car, or any sportscar for that matter. Rolls happen when you slide sideways into dirt and the wheels catch.
#5 The rear suspension is adjustable to a point. Ride height most notably. Have a quality shop do the work, it will require an alignment afterward.
#6 An F1 car isn't going to take a 30mph turn at 120mph. Besides hitting triple digit speeds on country roads could earn you a 1st place Darwin award. I'm no prude, I like to drive fast. But there's a time and a place. This is not to mention spending some time learning how to drive fast and how to control the car when you loose grip. I've done stupid things and got lucky (I'm sure all of us have). I'm just trying to keep you from using all your luck up at once- save that for the ladies!
#7 Timing belts on the 2.5L's require a considerably expensive tensioner tool. Don't attempt the belts without it.
The moral of the story- buy some good tires, sign up for some driving events, leave everything else stock, and keep the triple digit speeds away from hairpin turns. Repeat after me "I have a Porsche, I don't need to draw anymore attention to it because it does it all by itself" :-)
PS- I'm sure SCCA has events near you too in addition to PCA.
Good luck,
-nick
AaronM 06-21-2004 06:54 PM
If you have some sure way of stopping one of the wheels with the car on jackstands, engage the clutch and see if the engine stalls or if it just spins the other wheel. Alternately, you can try spinning the non-braked wheel with your hand. If it spins, then no LSD (transmission in neutral of course).
Both should spin in the same direction if it's an LSD when you spin them with the car up in the air.
These cars are infamous for a "whine" from the gearbox at speed, but noises at low speed are bad. Check the gear oil for metal particles and replace it with new. Best case, you have fresh gear oil. Worst case, you find metal bits and know that your transaxle is dying instead of finding out the hard way when it grenades on the road somewhere. These are not extremely robust transaxles and they don't take kindly to any rough treatment. Speed-shifting and hard stars can give these things problems fairly quickly. Also, the differential and transaxle share lube, so if one goes and puts metal into the lube, then the whole setup is at risk.
Aaron
Imwithstupid^ 06-21-2004 07:14 PM
Ok so the tire set up i have decided on is this
225 50 zr 15 for the front
245 50 zr 15 for the rear
does that sound good? I have Enkei gold/chrome rims which i think are 8 inches wide. Thats what they measure from side to side, but they could be 7's i am not sure. I have the sport shock/sway bar option on my car (456).
The turn is a suggested 30mph. It's really not that bad but i do find myself slowing down to around 35 when driving my parents suv or other cars. It's really not that sharp, but because it has absolutely no bank or shoulder i believe it is limited to 30mph. When i say backroads, i mean BACKROADS. There is absolutely no one who lives out here so this is where i practice. To give you some idea of the desolation of this place, my parents bought our farm for about 200k. it has 102 acres, 5 oak barns, a house, a pond, and some of the best farmland in delaware. So obviously no one is too interested in living here. They did recently build a Wal-Mart Supercenter about 12 miles away. I am sure this will help to populate my rural community.
AaronM 06-21-2004 08:15 PM
Make sure the wheels will fit your car. These cars have somewhat odd backspacing (aka "offset") and while the bolt pattern may match up, wheels with the wrong backspacing will cause problems.
Aaron
Imwithstupid^ 06-21-2004 08:19 PM
The guy i bought them from had them on his 944 and assured me they would fit. Then he proceeded to tell me that 245 was the sidewall width and 50 was the tread width. I just paid for them and left without arguing.
Z-man 06-22-2004 06:41 AM
Shawn:
1. You don't have LSD. The tell-tale sign is the if you spin one wheel, the other spins the opposite direction - you have an open diff. The fact that you can leave two black marks on a smokey burnout doesn't prove anything except that you like to abuse your car! :eek: Think about it: an LSD helps if there is an unequal amount of traction to the real wheels. If you are on asphalt or concrete, then the grip to the rear wheels is equal, thus two nice strips of black, and two steps closer to a new tranny!
2. Regarding tires: OEM tires on your '84 944 are: 215/60-15. Optional tires were: 205/55-16 front and 225/50-16 rear. That said, while the tires you want MAY fit on your car, your odo reading may be off. On my 944S2, I had 205/55-16 front, 225/50-16 rear, but have gone up to 225/50-16 front and 245/45-16 rear. When you work out the numbers, the diameter on tires + wheels are equal in all three sizes (ie: 205/55-16 = 225/50-16 = 245/45-16) Just ask your local tire guy the proper aspect ratio for a wider tire. I think the 245/50-15 you suggest will be too tall.
HTH,
-Z-man.
Imwithstupid^ 06-22-2004 07:07 AM
Well im not worried about the speedometer or odometer. My cable broke and rather than replaceing it just bought a gps and made a new gauge bezel for that and my digital gauges. So you are saying i should get 245/45-15? Thanks, I'm gonna ask ym tire place how much they are gonna want for tires and such.
Z-man 06-22-2004 07:16 AM
Check with your tire place. I know 245/45-16 works for my car, but I am unsure if 245/45-15 would work for yours.
-Z.
Imwithstupid^ 06-22-2004 07:31 AM
Ok this might sound stupid, but where are the measurements of rims taken from?
outer lip to outer lip is 8"
top to bottom is 16"
The diameter is the same as my cookie cutter wheels so are they 15's or 16's?
Texas944 06-22-2004 08:08 AM
the first number is the tread width in millimeters, the second number is the sidewall height as a percentage of the tire width, and of course the third number we already know!
Z-man 06-22-2004 08:26 AM
Shawn:
The tire size should be stamped on the wheel - look for something like 7Jx15 or 8Jx16 (7 & 8 designate the width of the wheel, while the 15/16 designate the diameter of the wheel).
Also: look at the tire you have on the wheel - the last number in the sequence will be the diameter of the wheel. (Ex: 225/50-16 - the wheel is a 16" diameter)
-Z-man.
PS: Tirerack.com has some good documentation about wheel and tire sizes.
nickd 06-22-2004 09:34 AM
245/50/15 will be pretty close to the stock diameter. No problems there. However, a 225/50/15 will be much shorter than stock and since the speedo is driven off the front wheels, your speedo will read too fast (ps- ditch the GPS and get the factory gauges working).
Wheel width is usually measured from the inside lips of the wheels, not the outside. If you're measuring 8" on the outside then I bet you have 7" wide wheels. That isn't really optimal for 245 width wheels at all. In fact, I wouldn't put anything wider than a 225 on it. You're contact patch could actually decrease if you use a 245 on a 7" rim as opposed to a 225. Not to mention the sidewalls will be bulging regardless.
There are no problems fitting those sizes under the fenders as long as the offset of correct and you have wide enough rims.
-nick
Imwithstupid^ 06-22-2004 12:30 PM
I dont have any of the stock gagues. My wiring was all to *****, not just the ground. none of the bulbs worked, my odometer wasnt working, my speedometer cable broke, my oil pressure gague wasnt accurate, so i repalced them all with digital gagues.
Being that i could use a digital speedometer, i bought a Garmin GPS II which is in my dash now. I will take pics. The leather backround somehow reacted with the sun and bubbled up, but i am going to overlay it with brushed aluminum when i get the chance. Right now i just want to get the car back on the road.
If they are 7" rims i would put 245's on them, but could i go with 235's? Ok supposed both possibilities, either 8 in or 7 inch rims, which tires would be the best for handling?
Z-man 06-22-2004 01:19 PM
With a 7" rim, the 'fattest' tire that safely fits is 225mm.
With an 8" rim, the biggest you can safely go is 245mm.
Imwithstupid^ 06-22-2004 01:38 PM
so would 225s be better than 245s? They are 7 inch rims so should i get 225/50zr15 or 225/45zr15? Or is there a better tire for handling?
Imwithstupid^ 06-22-2004 07:55 PM
How much do you think i could get for my 944? Do you think i should sell it and buy a 1993 camaro z28? I would twin turbo charge or supercharge it as my next project.
