thermostat question
if I take the thermostat out is it stamped or marked in some way that I will be able to tell if it is the stock one or a cooler one?
what would happen if the thermostat turned out to be cooler than stock and the thermo switch was stock?
I ask because I'm pretty sure i need to replace the thermo switch (based on a couple of other questions I;ve asked here ) and i talked to the PO and he "Thinks" he put in a cooler thermostat but doesn't remember for sure .
Thanks,
Gary
1982 924 Turbo
Old 06-28-2004, 04:49 AM
mine actually ran hot with a low temp stat and a stock thermo switch.
It ran above the 3rd mark.
I had to put in a low temp switch to match ths stat.
Now it runs below teh half way mark.
Try it and see though. mabey youll get lucky.
Current: 1973 914/4 project. FOR SALE
Old 06-28-2004, 10:52 AM
Brian J's Avatar
Send a message via Yahoo to Brian J
Re: thermostat question
IMO if you have out the old thermostat. Just put in a new one.
Drive it the way it was built to be driven!
http://www.pelicanparts.com/gallery/Brian_J
Old 06-28-2004, 11:44 AM
TCMdocs944's Avatar
I should be stamped. You may have to really look for it (as in, on the inside somewhere)
I am an advocate for matching the thermoswitch and the thermostat. It caused me and the PO all kinds of headaches until I finally replaced both with the cooler temp.
Now, two things....
One ----- I AM in florida - 60% or better humidity ALL YEAR LONG + heat.
Two ------ Sometimes lower temp units are put in to cover up other cooling issues.
83 944 white w/Boxster wheels
Planned mods- custom leather interior, 968 antenna, soundsystem, 968 style rockers, clear sidemarkers
Old 06-28-2004, 02:23 PM
