2.8 conversion
Hey guys I have a extra 85.5 944 enigne sitting around and I was thinking about slowly building a race motor with it. Does anyone know what is need to do a 2.8L conversion?? Any good links?? any ideas??
1986 951, Stock for now. ]87 924S Gaurds red- SOLD after 11 years of ownership |
Non Compos Mentis
Make sure you read the rules for whatever race class you want to run BEFORE building the engine.
S2/968 crank makes it a 2.8 doesn't it?
95 240sx-track slut w/ too much done to list 87 944 n/a-old "toy" that broke too much |
Im not to worried about the racing class, with the mods I have now Im already in the GT class
bump
Used & Abused
PH 2.8L Kit: New 968 longer stroke crankshaft, 4 custom forged lightweight connecting rods (2lb lighter than OEM), lightweight custom 2.8 L Mahle 8.5:1 pistons & rings & wrist pins
Base Kit = Call + the following upgrades: Customize the 3.0L crankshaft: cross drill rod journals, knife-edge & remove 8 lb., balance Precision bore cylinder block to assure perfect piston-to-wall clearance (1st oversize bore) Complete engine gasket set, with Wide Fire Ring head gasket and new head nuts & washers Complete engine bearings: racing mains, connecting rods, balance shafts & oil pump sleeve “O” Ringed cylinder head, valve job, new guides, valve springs, ported & polished (exchange) 8x new hydraulic lifters - must be replaced if not done recently, or on engines over 75k mi. New timing belts, tensioners & rollers kit New 3.0L water pump New oil pressure relief valve & sending unit Modify the oil pan & pick up tube to help prevent oil starvation to rod bearings (exchange) All new water & vacuum hoses 3 Bar fuel pressure regulator Clean, pressure flow & balance your OEM fuel injectors Stolen from powerhaus.
83 - 944, daily driver 62 - VW Karmann Ghia, never moving restoration "Oh Bother," said Pooh, as he chambered another round. |
Used & Abused
I wonder what's involved in putting in the 968/3.0 water pump.
I'll look up to see how much you need to bore the cyls.
Yea It looks like a nice package, but I really dont want a CR as low as 8.5 to 1, Im thinking like 10.5 or 11.5 to 1, Its gonna be a NA so I need the CR for more HP
Used & Abused
Alright, did some math.
924S = 2.5ltr, 100b*79s 2.8 = 100b*88s 968 = 3.0ltr, 104b*88s Since you have to overbore the cyls by 2mm (deep scratching you said), you are going to have a 2.9ltr engine using 88mm crank. You could have a 2.7 (2656cc) if you overbore to 103.5 w/ the stock crank. Do the work right and you can set compression up to 13:1. Need more compression? shave the head back down. The 8.5 specs are on the idea you're turboing the motor.
