-   -   Power Steering Bracket?? (http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/171072-power-steering-bracket.html)
rachwalj 07-06-2004 08:21 AM
Question for anyone with an unmolested 944. My PO did a number on this car, and one of the numerous things is this, hand-made, hack-sawed bracket that holds the power-steering pump. I'll post a picture when I can get under it. He drilled holes in this thing at various places. I think it is actually part of a lawnmower blade, I ***** you not.
I just want to know, what is SUPPOSED to be there? Does anyone have a picture / part description, so I can properly fix this?
Thanks all.
AFJuvat 07-06-2004 10:42 PM
See picture below.... (the big triangular thing)
http://forums.pelicanparts.com/uploa...1089178740.jpg
If that is the part you need, you will need to remove the timing & balance shaft belts, as well as the belt covers, and crank pulley to get at it.
Part is still available from Porsche - I just replaced on in a car last week. It runs about $1250.00
Used ones may be available.
AFJuvat
rachwalj 07-07-2004 07:07 AM
WHOOOAAAA Horse... Yaaaah!!!
I just need some sort of bracket. If this is a 1250 part, then I can understand why he used a lawnmower blade...
I have to post a picture. What I need is an adjustable tensioning bracket. I have a friend who is a machinist, I'll have him carve me up something.
-J
will944 07-07-2004 09:07 AM
rachwalj
Are you just talking about the pivot bracket for the pump? If so, I don't think AFJuvat's picture is the correct one. I do have a pic....but is on my computer at home. I will post it when I get back this evening.
JRMock 07-07-2004 10:43 AM
My swag is your are looking for the adjustment rod/strut. These can be found for around $35. One place that has them is...
http://www.944online.com/newparts.asp
The picture in the top right has the rebuilt pump and adjustment rods.
Is this your part?
JM
:cool:
rachwalj 07-07-2004 11:04 AM
Awesome... thanks
will944 07-07-2004 07:01 PM
This should help.....
http://img43.exs.cx/img43/8837/ps.jpg
