Power Steering Bracket??
Question for anyone with an unmolested 944. My PO did a number on this car, and one of the numerous things is this, hand-made, hack-sawed bracket that holds the power-steering pump. I'll post a picture when I can get under it. He drilled holes in this thing at various places. I think it is actually part of a lawnmower blade, I ***** you not.
I just want to know, what is SUPPOSED to be there? Does anyone have a picture / part description, so I can properly fix this? Thanks all.
SOLD 944 n/a. Searching for next endeavor... |
See picture below.... (the big triangular thing)
If that is the part you need, you will need to remove the timing & balance shaft belts, as well as the belt covers, and crank pulley to get at it. Part is still available from Porsche - I just replaced on in a car last week. It runs about $1250.00 Used ones may be available. AFJuvat
Es geht nicht darum wie schnell man faehrt, sondern wie gut man schnell fahren kann. Ihr Brunnen der nutzlosen Porsche Information |
WHOOOAAAA Horse... Yaaaah!!!
I just need some sort of bracket. If this is a 1250 part, then I can understand why he used a lawnmower blade... I have to post a picture. What I need is an adjustable tensioning bracket. I have a friend who is a machinist, I'll have him carve me up something. -J
rachwalj
Are you just talking about the pivot bracket for the pump? If so, I don't think AFJuvat's picture is the correct one. I do have a pic....but is on my computer at home. I will post it when I get back this evening.
10 E92 M3 13 Jeep GC Limited 98 Jeep Cherokee 87 951 C3 Stingray |
My swag is your are looking for the adjustment rod/strut. These can be found for around $35. One place that has them is...
http://www.944online.com/newparts.asp The picture in the top right has the rebuilt pump and adjustment rods. Is this your part? JM
Awesome... thanks
This should help.....
