Send a message via AIM to stuttgart93
1977 Porsche 924 starter trouble
I just tried to start my 924 the other day. It turned over fine for a few cranks, then all the sudden nothing happen except the starter continued to spin in the crankcase without touching the flywheel. I turned the key all the way off and pulled the key out and the starter was still spinning. So then i was forced to pull off the battery terminal and then it stopped. right after that i touched the terminal back on the battery and the starter immediately begins to spin like before. That is what happens now everytime. Can someone PLEASE help me im running out of options. I've disconnected ignition control box, ignition switch, coil to try and illiminate the problem but it still starts spinning with key off and battery connected....PLEASE anybody help
thanx, Zack
Old 07-07-2004, 02:06 PM
nickd's Avatar
Easy, your wires that run down to the starter & alternator have melted together. You're not alone. This is probably on the top 5 of early 924 problems. The solution is to either buy a new harness from the dealer (around $80 I think) or build your own with wire/terminals from your local auto parts shop.
To keep it from happening again you need to make sure all your heat shields are in place, the wires are covered with the heat resistant sleeve, and the wires are pinned back away from the exhaust.
Good luck- it's kind of a pain, but you'll find your car starting much easier and your alternator putting out more volts too.
-nick
1991 964 C4 Cabriolet - drop-top pylon destroyer
Old 07-07-2004, 05:55 PM
