-   -   In a related note..... (http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/173263-related-note.html)
AFJuvat 07-19-2004 06:33 PM
Called the dealer today about the 944 that ate the oil return tube last week.
Surprisingly, Short blocks for the 944 are still available on an exchange basis.
Retail is $4400.00
AFJuvat
Moneyguy1 07-19-2004 06:36 PM
Lots of money for a potential boat anchor.......
I assume when they say "exchange" they want one that is rebuildable, though...and most times, when I have gone for a major part like a block or head it was because the original was NOT salvagable.
Makenzie71 07-19-2004 06:49 PM
I've never really understood that...most people who buy engines to install themselves are fairly mechanically inclined. The only reason I would buy a new shortblock is because mine WASN'T rebuildable.
Don 944 LA 07-19-2004 08:20 PM
( unknowledgeable here )
Is that for the complete engine ???
ilikemy944 07-19-2004 08:27 PM
shortblock = everything that is under the head...
like, block, pistons, crank, etc...
gearhead290 07-19-2004 09:03 PM
hmmm...I think I should go into the business of rebuilding Porsche engines...
mattdavis11 07-20-2004 06:45 AM
I would guess that Moneyguy1 is correct on the rebuildable issue. When I changed out the water pump, I had to pay the core charge. The impellers had eaten into the housing, so it was thrown in the dumpster. Boy did I get lucky!
jm951 07-20-2004 09:37 AM
For clarification, "everything under the head" does not include A/C comp, ps pump, alternator, oil pan. It is just the block, pistons, crank, rods. Generally you use the old flywheel and the rest of your old engine.
TCMdocs944 07-20-2004 10:51 AM
Bargains to be found everywhere at the dealer!
In this information/online age you think they would get a clue. I wouldn't mind paying a few bits more from the dealer if:
A. they had a knowledgeable, helpful staff
B. It was only a few bits not 400-500%
