Exclamation Warning lights come on
Hi all,
My problem now (Oh, how I love my car!) Is that the oil warning and brake warning lights are coming on. My revs are set to about 950 but sometimes the lamps flicker. If I rev the engine the lights go out.
I think it's an intermmitent electrical fault somewhere. Does anybody know how these lamps are driven? Is it the Electronic Ignition Unit?
Regards
Misty
Old 08-05-2004, 11:33 PM
Send a message via AIM to Makenzie71 Send a message via Yahoo to Makenzie71
what does the oil PSI read? Does it fluctuate? I would assume it's an intermittent ignition failure...check all grounds.
http://forums.pelicanparts.com/uploa...1093905626.jpg
the "baby" that comes first...
Old 08-05-2004, 11:51 PM
At idle, about 1-2. It doesn't fluctuate?
Old 08-06-2004, 12:09 AM
Why the questionmark? You don't know if it fluctuates? If the guage bounces erradicly (sp?) then a bad ground or a serious engine problem would be your likely choices.
Old 08-06-2004, 12:51 AM
The oil pressure raises and lowers depending on revs - that's the reason for ?
Engine is fine, I'm probably thinking more electrical. Do you know what drives these two warning lamps? I know they are supposed to come on when engine is very low revs (as if you are going to stall the engine.
Regards
Misty
Old 08-06-2004, 01:50 AM
flangermog's Avatar
Could it be something to do with the fairy lights in your dash? (sorry)
(x)'89 944 S2 Cabriolet (Guards Orange) :
( )'90 944 S2 (Maraschino Dead!) :
( )'89 Audi 90 Quattro 2.3 20V :
( )'92 Renault Clio 1.4 :
Old 08-06-2004, 07:50 AM
daxdog's Avatar
I emailed a buddy a link to the superbrightled.com site. He told me he tried to install led lights in his Mazda a while back. They ended up screwing up the relay and cause all sorts of electrical issues. A trip to the shop and $1200 later, he was back where he started before the led lights.
1984 Porsche 944 Silver/Black
Old 08-06-2004, 09:10 AM
MAGA
Tim Hancock's Avatar
When your oil pressure drops to this range at idle, these lights are supposed to come on. If your oil pressure is fine at cruise rpm then don't sweat it. How long has it been since you changed your oil? Did you use a different weight oil?
German autos: '79 911 SC, '87 951, '03 330i, '08 Cayenne, '13 Cayenne
0% Liberal
Men do not quit playing because they get old.... They get old because they quit playing.
Old 08-06-2004, 09:14 AM
Flangermog: I was thinking that! but it now seems to have righted itself.
Tim: I used some valve lifter cleaner recently, but I can't understand why the brake warning light is coming on too?
Old 08-08-2004, 11:23 PM
AFJuvat's Avatar
I would suspect that it is an issue with the new lights. That said, check all of the grounds and electrical connectiions on the intsrument cluster.
Which Brake Warning light is on?
AFJuvat
Es geht nicht darum wie schnell man faehrt, sondern wie gut man schnell fahren kann.
Ihr Brunnen der nutzlosen Porsche Information
Old 08-09-2004, 05:09 AM
The main one for the brake servo (Fluid level) Not the handbrake.
It's just annoying more than anything.
Cheers
Phil
Thanks for reply to the pressure cap question. Much obliged
Old 08-09-2004, 05:56 AM
