924 @#$% Tranny Noise
Left and turns ok right hand turns loud click thump noise and vibration. Cold! no noise. Hotter it gets the worse the noise! Removed Tranny and checked Bearings and damage no obvious defects. Changed Oil. No help. Once its hot and not moving I can take it out of gear and rev the engine and it make THE NOISE! What is it!!!!!!!!!!!!!!!!!!!!!!!!!!!
Blue is not a color its a frame of mind.
Old 07-22-2004, 01:25 PM
Probably either wheel bearings or cv joints.
From November 2012; Precision Porsche Specialist
Sussex UK, +44 (0)1825-721-205
2001-2012 Gerber Motorsport Inc. 206-352-6911
07.15.06 1996 Ducati 900SP. Suprisingly enough, it's red
08.16.09 1999 Kawasaki ZRX1100. Green.
Old 07-22-2004, 02:45 PM
tobster1911's Avatar
Re: 924 @#$% Tranny Noise
Wait....It makes the noise when you are not moving??? My vote would be engine mounts. Just my $0.02
'97 Saturn SL (tiny 1.9L bubble car)
'98 Grand Prix GTP (4dr family car with a bite FOR SALE)
'87 944S (Sold as a German engineerd money pit)
'78 Chevy 4x4 (What I drive when everything else is broke)
Old 07-22-2004, 04:03 PM
Burn the fire.
Brando's Avatar
not moving, with the clutch pedal in? describe the noise...
[x] Working | [_] Broken: 2017 Victory Octane
[x] Working | [_] Broken: 2005 Ram 1500 SLT w/5.7L Hemi
"Drive it like you stole it."
Old 07-22-2004, 09:44 PM
Used & Abused
Engine mounts bad usually make vibration at idle though.
CV joints or wheel bearings make the noise while turning but only in motion. Not while stopped.
Tranny mount? Exhaust mount?
83 - 944, daily driver
62 - VW Karmann Ghia, never moving restoration
"Oh Bother," said Pooh, as he chambered another round.
Old 07-22-2004, 10:44 PM
Stopped! Cold! Clutch in - no Noise. Clutch out - no noise!
Stopped! Tranny warm Clutch in - no Noise Clutch out - Noise!
The noise is in the tranny!!! Suspect Bearing or somthing Bent!
Checked torque tube bearing's Ok! I Have another tranny for parts will
Investigate this week end!
Old 07-23-2004, 05:46 AM
Burn the fire.
Brando's Avatar
probably a problem where the input shaft meets up with the gearing inside the trans?
not sure... mine has always had that 'whine' at 70+
Old 07-23-2004, 09:35 AM
