Head Unit Install Questions???
I have an 88 944 with the Blaupunkt tape player. How do you install a different head unit without using that quick release slide in/out setup. Is there a mounting kit for other head units or do you also use that quick release setup?
Thanks, Pat
1988 Porsche 944
~24K Miles & CLEAN
Old 08-11-2004, 05:35 PM
gearhead290's Avatar
Send a message via AIM to gearhead290
what quick release set up are you talking about?
I took my old head unit out, wired my new one to work, put that little sleeve that comes with it in the hole and bent the prongs to hold it in, and then I slid in the new head unit. It's really quite simple
95 240sx-track slut w/ too much done to list
87 944 n/a-old "toy" that broke too much
Old 08-11-2004, 07:02 PM
scheistermeiste's Avatar
Send a message via AIM to scheistermeiste Send a message via Yahoo to scheistermeiste
im pretty sure that all new head units are made the way that gearhead said with little keys that allow you to slide the headunit in and out.
Special Edition 924S 1988 <- SOLD!
Asking if you should replace that timing belt is like asking if you should re-use a condom that may have in hole in it with a hooker.
Old 08-11-2004, 07:26 PM
btsave's Avatar
you can use 2 pieces of wire hangers, each bent in a U shape... works well to remove the radio..
BTW Brandsmart has the Blaupunkt Miami Beach radio discontinued for $98, regular price $269...
Bart
Old 08-12-2004, 06:44 PM
