How to get 2 ga wire through firewall?
I have an 86 944 Turbo and i am trying to get 2 ga wire to the battery to power 2 amps. I tried searching on how to get the cable through the firewall without any drilling but all i found were a couple of vague responses. So basically how do i get this wire through the firewall? Keep in mind that i do not want to drill/cut. Pics and/or very specific locations would be very helpful. thanks.
Old 08-17-2004, 01:11 PM
I know there is a spot on the drivers side , next to the fuse box, behind the black rubber strip that runs from passenger side to driver side to seal the engine heat from fresh air. There is a big black grommet that is just below the bottom of the windshield.
Old 08-17-2004, 01:39 PM
bertman's Avatar
There's a nice access spot through the firewall at an existing grommet located directly behind the battery (at least on my early car). After fishing for the wire for awhile, I finally just removed my glove box to ease access to it. Piece of cake. YMMV.
bertman
84 944 Original Owner
65 Plymouth Satellite
08 Mercedes-Benz E 350 Sport
Old 08-17-2004, 01:42 PM
ae1969's Avatar
Send a message via ICQ to ae1969
Yup there is a hole right behind the battery as mentioned by bertman....... it should have a rubber grommet that reappears behind the glove compartment.
Alex - PCA Polar Region - Boxster Muncher
86' 944 Turbo - Megasquirt - 326 rwhp/340lbft @ 18 psi SOLD
www.edmontonhomelife.com
www.edmontonrealestate.ws
Old 08-17-2004, 03:10 PM
SoCal Driver's Avatar
It's the pass through for the antenna in the windshield. Be careful not to pull the wire out of the windsheild.
Hugh - So Cal 83 944 Driver Person
NOT a 'real' Porsche -- Its Better!!!!
When was the last time you changed your timing and balance belts and/or cam chain and tensioner?
New Users please add your car's year and model to your signature line!
Never break more than you fix!
Old 08-17-2004, 08:58 PM
yah i see the one by the battery but is that big enough for 2 ga wire? Also, how do you take it out...pry it out with a screw driver? Thanks for the replies so far.
Old 08-18-2004, 05:54 AM
Pry the grommet out. Use a round file to slightly enlarge the hole. Pass your 2 gage wire through the grommet. Use silicon spray to help the grommet back into the hole. You may have to remove the glove box to get to the other side of the grommet to get it back in. Don't leave the grommet out.
While you are fiddling with the wiring. Jack up the car and clean the connections on the starter. The large wire. This is the path the alternator power comes back through. Might want to get an adjustable regulator for your alternator and tweak it to 14.6 volts.
Old 08-18-2004, 08:29 AM
how do i fit the grommet back in when i have the wire taking up the space? Do I need a new grommet with a hole in it or can i just use plumbers puttty, etc.? thanks.
Old 08-18-2004, 10:01 AM
