-   -   Engine Malfunction (http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/178673-engine-malfunction.html)
frankzoolu 08-20-2004 05:21 PM
Engine Malfunction
Does anybody know why my car would be stuttering on acceleration? If I give it some throttle it will start cutting out around 3000rpms. It’s almost like its flooding or not getting enough gas. Could this be a timing issue? I recently changed all of the belts and rollers when I did my motor rebuild. I don’t know if I might have the cam a couple of degrees out. I tried checking my TPS, which seemed to be ok. If anybody has any ideas please let me know.
frankzoolu 08-22-2004 08:37 PM
I tried to pump more pressure through my fuel system but this did not seem to help. Any ideas that somebody may have would be very usefull.
Makenzie71 08-22-2004 08:38 PM
plugs/wires/filters
frankzoolu 08-22-2004 08:41 PM
All of that stuff is brand new. I pulled a plug and it did not seem to be fouling up.
adida(r 944) 08-22-2004 09:06 PM
try checking all the electrical connections in the engine compartment. like the speed and reference sensors, afm sensor, thorttle body sensor, those types of things. you may have them connected but they might be loose.
