Banned
light flywheel 0-60
Silly question, I know if been post # crazy times , But a fidanza lightweight flywheel, will reduce the 0-60 in 944na 1 second???or not !!!!Is true all benefits less stress in main bearing and rev faster ! who has one!!!!what good and bad can be say about it!
Old 03-15-2006, 08:56 PM
BananaClip's Avatar
Send a message via Yahoo to BananaClip
I can't tell if thats a question or a statement so I'm gonna go ahead and say it probably won't be that marked of a difference. I bet it helps the butt dyno though.
keep the dream alive!
1988 944 NA (purple)
Old 03-15-2006, 09:26 PM
Eldorado's Avatar
welcome back alina..
agreed... if it's performance you want, it definitely isn't the best bang for your buck.
Kyle
2008 Mini Cooper // '83 Porsche 944 // '01 Mazda Protege [sold] //
"Never break more than you fix!" - SoCal Driver
Old 03-15-2006, 09:35 PM
Dtchy's Avatar
Why not turbo your NA?! Ajajajajajajajaja!!!! That's fast!
Horsepower is how fast you hit the wall...Torque is how far you take the wall with you...
1994 BMW 325is M-Technic
1986 Porsche 944 N/A
Old 03-15-2006, 10:26 PM
Writer/Teacher
CJFusco's Avatar
Send a message via AIM to CJFusco
Well, alina, it will make your car rev faster. The problem with this is that first gear in a 944NA is geared WAYYYY too short to get any kind of accelleration out of it in the first place, so now you're gonna have a first gear that's pretty much useless, and most of your accel will occur in 2nd... I can't see the car being any faster off the line. You might get some corner-to-corner accelleration in 3rd/4th, however...
Current Stable: Black 07 Porsche 987 Cayman S: Long-Tube Headers; FabSpeed Exhaust; VividRacing ECU Tune; IPD Plenum; 997GT3 Throttle Body. Blue 1983 Porsche 928S. 1985.5 Porsche 944 Rat Rod. 2011 Acura MDX. 2008 Mazda 3. Gone But Not Forgotten:Garnet Red 86 Porsche 951("The Purple Pig"). Alpine White 83 Porsche 944 ("Alpine Wolf"). Guards Red 84 Porsche 944.
Old 03-16-2006, 06:50 AM
Dog-faced pony soldier
Porsche-O-Phile's Avatar
I don't see it doing really anything. The engine needs to turn a crankshaft, associated pulleys, a transmission and axles, torque tube and wheels. It also has the load of a 2,500-pound (or more) car on it. The effect of shaving a couple ounces off a flywheel is negligible.
As has been said though, with no load on the engine (clutch in or in neutral) it will raise/drop revs more quickly due to less rotational mass (and less effect of inertia). So heel-toe throttle "blips" might end up being more effective, though I find you can get the same result by varying driving technique and pushing the pedal down a little harder and a little earlier.
For the cost and effort of such a thing, there are WAY better places to spend your money.
I also wonder about the implications of deleting mass from a flywheel which helps to dampen out power stroke "pulses" from the engine. The balance shafts are solely intended to counter second-order harmonics inherent to four-cylinder engines, much as a harmonic dampener would. They are not intended to dampen out power stroke pulses - that's what the flywheel is for. I can't help but think that it would be detrimental to engine life over long term to remove mass from this device, but for a seldom-run race engine it is probably okay.
Whatever thrills ya'.
Black Cars Matter
Old 03-16-2006, 07:14 AM
Non Compos Mentis
Light flywheels have plusses and minuses. The Porsche factory engineers are pretty fanatical about weight. The factory flywheel was considered to be the best compromise between performance, and ease of driving.
That being said, my 911 has a very light flywheel, and I love it. Every last little bit helps when autocrossing. But everything I've done to the car makes it less friendly to use as a street car.
Stiff suspension- Rides hard
Short gears-High RPMs on the highway, uses more gas
Stripped interior-Noisy
Racing seats, 5-point harnesses- Can't shift positions on a long drive
Light flywheel- Easy to kill the engine, need to blip the throttle even on upshifts.
But I made the car the way I want it. I wouldn't change a thing.
Old 03-16-2006, 07:46 AM
winter-hater club member
nynor's Avatar
i bet it gives you about 197HP in your best NA
"COOL PRIUS!" - Nobody Ever
Old 03-16-2006, 08:24 AM
Non Compos Mentis
It takes two additional stickers (minimum size 2"x8") to achieve 197 hp.
Old 03-16-2006, 08:49 AM
PhillysMostWntd's Avatar
Send a message via AIM to PhillysMostWntd
the stickers need to be yellow or red for best results
ajajajajaajaaaaaaaaaaa..
1984 Porsche 944 - down for the count, may be rebuilt
1999 Civic ex coupe - Turbocharged fun/Daily Driver
Old 03-16-2006, 08:57 AM
nynor's Avatar
butzi, i wanna see pictures of your ride, just for the record.
Old 03-16-2006, 10:13 AM
Eldorado's Avatar
lol nynor is back... here we go again...
Kyle
Old 03-16-2006, 10:59 AM
nynor's Avatar
yeah, i stayed away for awhile, but its like that chipped tooth you just can't leave alone.
if butzi posts a legit picture of his/her/its 944, i'll butt out.
Old 03-16-2006, 11:39 AM
nynor's Avatar
for the record: i never left!
also, for the record: i have a fidanza. i have no idea what difference it makes for accelleration, as i've only experienced it in my turbo from the day i bought the car. that said, it does seem to take a bit more finesse shifting, especially from a stop.
Old 03-16-2006, 11:58 AM
