-   -   Motor Mounts on S2...How much $ to replace? (http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/180904-motor-mounts-s2-how-much-replace.html)
ICD 09-03-2004 10:17 AM
I'm looking at an S2 that will need one or two motor mounts. What is the parts and labor for each side?
krahm 09-03-2004 02:21 PM
If you're feeling adventurous and you've got the tools and garage space, it's not an impossible job for the novice mechanic. Clark's Garage has a good article on how to do it. I've done it myself, but I haven't paid to have it done, so someone else should probably advise you on that, if I'm way off, here. I'd guess, though, that you'll probably pay around $90-$130 per mount from the shop, depending on whether you opt for OEM or aftermarket parts. Then add in maybe 3 to 4 hours labor. If you go to a dealer, expect to pay big $ for both parts and labor.
Personally, I'd advise you to do both sides at the same time. You've got to drop the cross-member to do the one, and the other is right there and ripe for the picking. You'll end up paying for the labor again when the other side fails. Rumor has it that you'll want to pay the extra dough for the OEM parts, too. Supposedly the aftermarket mounts are crap.
nize 09-04-2004 11:36 AM
how long are these mounts supposed to last? or a better question might be, how long have they lasted for you in the past?
944 Ecology 09-04-2004 12:40 PM
I have a pair of motor mounts in my 83 track car that have lasted since I replaced them in 1989.
gb
nize 09-04-2004 01:25 PM
are you sure they don't need to be replaced? i've read that they need to be replaced long before they start showing visible signs of deterioration and the only way to know for sure is to measure them via a special tool.
well, either that or the engine vibrations. :)
