-   -   Early oxygen sensor installation (http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/184662-early-oxygen-sensor-installation.html)
TCMdocs944 09-27-2004 06:11 PM
I just installed a new O2 sensor on my 83.
7/8ths long handled wrench.
$20 universal one-wire o2 sensor from bosch
Warmed car up
Put on ramps
Twisted old sensor off easily
Cut old wire
Crimped and heatshrunk new wire on
Tightened her in
Done deal..
That had to be the easiest job I have ever done on the early...sorry for you late and 951 guys.
Early guys....GET ON OUT THERE AND CHANGE THOSE O2 SENSORS!!SmileWavy
TCMdocs944 09-27-2004 06:12 PM
BTW- car ran a little rough for the first few minutes post o2.
THEN
My stumble at 3300-4300 under load is GONE.....??????
With all my research I have yet to hear that one. I will have to drive tommorow more and see if it is really true.
a.n.other 09-27-2004 07:27 PM
I'll second the easiness of the O2 sensor installation - at least until my only cigarette lighter i was using for the heat shrink run out of gas and i had to use matches which kept on blowing out in the wind - hrmph!
MikeCT 09-28-2004 11:19 PM
Do they carry that at autozone or some place similar?
TCMdocs944 09-29-2004 09:01 AM
Yes. I got mine from pepboys but the local autozone carries them as well.
a.n.other 09-29-2004 09:52 AM
I got mine from Kragen - Bosch 11027 for my non-California car. The non-Ca cars have just a single wire and the Ca cars have three - it will be worth having a quick look down at the exhaust pipe from under the hood to see which one you need before you buy one.
http://www.partsamerica.com/PartDetails.asp?SourceArea=&SourcePage=SEARCHRESUL TS&MfrCode=BOS&MfrPartNumber=11027&PartType=291&PT Set=C
