Mein Gott!
Panzer909's Avatar
Is there an upgraded center cassette door hinge?
For the second time in abot three years, my center console door hinge tore. I always wondered why Porsche used such cheap plastic for this part and am wondering if there is any "upgraded" version out there? The original replacement is only about $25 but it will eventually break soon enough.
Anyone care to chime in here?
Johnny
1987 944S
1984 944 (R.I.P.)
1972 Triumph TR6 - 100% trouble free between breakdowns
2003 BMW 325xi
Old 10-06-2004, 08:48 AM
A PO simply used a piece of nylon webbing, and ran the screws through it. It isn't as solid as a hinge would be, but much more durable. I haven't been inclined to use the good hinge from my parts car.
'86na, 5-spd, turbo front brakes, bad paint, poor turbo nose bolt-on, early sunroof switch set-up that doesn't work.
Malo periculosam, libertatem quam quietam servitutem.
Old 10-06-2004, 11:02 AM
Zero10's Avatar
Send a message via ICQ to Zero10
I'm about to fix mine. I plan on epoxying some piano hinge in, or cutting out a little bit of the frame, and screwing it in.
I'll let you guys know how it works when I get around to it.
Might need a small about of metal bending on the bottom part, but I have a heavy-duty sheet metal brake, so no problem.
2010 Hyundai Elantra Touring, GLS 5 speed, Indigo Blue Metallic. 2.0L of Korean fury!
Buy my parts!
Old 10-06-2004, 01:31 PM
livewirevoodoo's Avatar
Similar to what I did.. Mine hinge came broke from the PO. I used a strip of black leather from a coat i was throwing away. Matches the console color well enough, to the untrained eye it doesnt look a bit out of place.
''87 944na 85k
C02 / M158 / M418 / M425 / M431 / M454 / M533 / M650 / M946
'94 Oldsmobile 88 Royale (winter beater)
Its not what you drive, its what drives you.
Old 10-06-2004, 02:06 PM
Mein Gott!
Panzer909's Avatar
Whoa. Those are some cool home brew ideas that I would have never thought of. But I guess what I'm trying to ask is if anyone here ever saw a metal-hinged (or sturdier) aftermarket part(?) Maybe Performance Products or something like that?
Johnny
1987 944S
1984 944 (R.I.P.)
2003 BMW 325xi
Old 10-06-2004, 03:08 PM
vott does ziss do?
ronin's Avatar
yes. Performance Products has one. perhaps Wayne sells them as well. check the site
Old 10-06-2004, 08:12 PM
