Quick oil change question please.
Hey guys,
Its time for some fresh Mobile 1 full synthetic oil for the winter and I haven't done a oil change in any of my other 944's before...
What size is the underneath engine plastic pan nuts and the oil pan bolt?
Thanks much!
89 Porsche 944
Owner: AutoFreeFinders.com Online Auto Mall
Old 10-11-2005, 10:20 AM
Parrothead member
VINMAN's Avatar
17MM I think...
Vinny
Old 10-11-2005, 10:42 AM
10 mm socket for the pan bolts. I think the oil drain plug is 15 mm but I would not want to bet on it. It's either 15 or 17 mm. The plug sizes on my cars are all different so I have trouble remembering.
Oil filter is going to dribble all over the place when you remove it.
Lawrence
1986 951
2002 SLK32 AMG
1987 328GTS
2011 528i
Old 10-11-2005, 10:44 AM
bryanthompson's Avatar
Send a message via ICQ to bryanthompson
84 944 can't get oil drain plug out.
Don't overtorque or forget the metal washer. Oil filter can be a biatch, drain oil and try to use a strap-type wrench.
Do you have a new oil filter already? If not, get a Mahle from Pelican (they sell the metal washers for .25 also.
1983 944 - Sable Brown Metallic / Saratoga / LSD : IceShark Light Kit
Old 10-11-2005, 10:52 AM
Thanks guys...
Yes, I already got a filter...
I need to organize my tools, sounds like a good winter project...
89 Porsche 944
Old 10-11-2005, 10:57 AM
You are correct sir...15mm it is!
Thanks guys, now on to my next project 944...The drivers door handle...
89 Porsche 944
Old 10-11-2005, 04:01 PM
Ah, the door handle tune-up. Last time I had that much fun was when I replaced the thermostat.
Old 10-11-2005, 06:16 PM
Once the oil filter is loose enough to turn, puncture it and let it drain into the oil pan. Then wrap it in a baggie and twist it off being quick to wrap the baggie around the open end.
Works for me.
Still get a few dribbles, but no flood!!
Bob S. former owner of a 1984 silver 944
Old 10-11-2005, 06:24 PM
Politically Incorrect
onZedge's Avatar
Puncture it where?
Edek
'87 924S
'91 535i
Old 10-11-2005, 10:14 PM
I was afraid someone would say that...A real bear to do?
89 Porsche 944
Old 10-12-2005, 09:51 AM
Cars & Coffee Killer
legion's Avatar
A strap wrench works well for the NA cars, but you need to get the fitted oil filter socket for a turbo. No room under the hood to move a strap wrench...
5 liters of VVT fury now
-Chris
Old 10-12-2005, 10:18 AM
