Hi Folks,
I just got a Weltmeister throttle response cam for my 86' 944 NA. But the installation iinstructions is a very poor photocopy which makes it very hard to read. Does anyone have these instructions handy? I know this is suppose to be a straightforward installation but I want to make sure I don't mess anything up (ie. the throttle cable). Thanks much! Humberto- |
I dont have them handy but its really hard to mess it up, Just unbolt the old one and bolt on the new one, When finished make sure the cable is adjusted right.
1986 951, Stock for now. ]87 924S Gaurds red- SOLD after 11 years of ownership |
How do I adjust the cable? Do I just re-adjust the two 13 mmm jam nuts ? What about the throttle pedal itself?
Thanks again... Humberto- |
entertaining the idea
There is an stop just behind the gas pedal. It has to be adjusted to account for the shorter throttle cam. This will decrease undo stress on the throttle cable.
There are some who call me... 'Tim'. a well set-up 1983 Guards Red 944 |
Writer/Teacher
Current Stable: Black 07 Porsche 987 Cayman S: Long-Tube Headers; FabSpeed Exhaust; VividRacing ECU Tune; IPD Plenum; 997GT3 Throttle Body. Blue 1983 Porsche 928S. 1985.5 Porsche 944 Rat Rod. 2011 Acura MDX. 2008 Mazda 3. Gone But Not Forgotten:Garnet Red 86 Porsche 951("The Purple Pig"). Alpine White 83 Porsche 944 ("Alpine Wolf"). Guards Red 84 Porsche 944. |
It was in the set of instructions that came with mine. The stop is brought up due to the gas pedal travel being shortened.
Makes sense otherwise one can break the cable...How did you shortened the cable though?
Humberto- |
Just adjust the nuts on the cable. Also when you adjust the pedal stops, its alot easier to have a buddy watch to make sure when you push the pedal down that the throttle body is opening all the way.
Writer/Teacher
that does make sense, because WOT for me is now much shorter than the pedal to the floor
this was not in my set of directions!!!
why did you spend money on the response cam when you can make it yourself with the old factory one?
I did not spent any money. I got it as a present...
Writer/Teacher
ditto
Armando Diaz 85 911 Carrera - Track car 01 996 Carrera - For Sale http://forums.pelicanparts.com/showthread.php?s=&threadid=327823&highlight=996 87 944na - Old Daily Driver, now 944 CUP 03 Chevy Avalanche- Support Vehicle 70 Olds 442 W30 Conv- Gone but not forgotten http://www.diazracing.com adiaz@diazracing.com |
you should be able to just cut off the arm
keep the dream alive! 1988 944 NA (purple) |
Writer/Teacher
i believe you turn it upside down and backwards, and drill a new hole for the mount... and then the angle is the same as the welmeiser cam.
This was covered awhile back here... wish i could remember the thread.
