-   -   Throttle response cam installation instructions (http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/186352-throttle-response-cam-installation-instructions.html)
Calvani 10-09-2004 01:34 PM
Hi Folks,
I just got a Weltmeister throttle response cam for my 86' 944 NA. But the installation iinstructions is a very poor photocopy which makes it very hard to read.
Does anyone have these instructions handy? I know this is suppose
to be a straightforward installation but I want to make sure I don't mess anything up (ie. the throttle cable).
Thanks much!
Humberto-
fast924S 10-09-2004 03:59 PM
I dont have them handy but its really hard to mess it up, Just unbolt the old one and bolt on the new one, When finished make sure the cable is adjusted right.
Calvani 10-09-2004 04:43 PM
How do I adjust the cable? Do I just re-adjust the two 13 mmm jam nuts ? What about the throttle pedal itself?
Thanks again...
Humberto-
UconnTim97 10-09-2004 11:12 PM
There is an stop just behind the gas pedal. It has to be adjusted to account for the shorter throttle cam. This will decrease undo stress on the throttle cable.
CJFusco 10-10-2004 06:57 AM
never heard about this
UconnTim97 10-10-2004 07:11 AM
It was in the set of instructions that came with mine. The stop is brought up due to the gas pedal travel being shortened.
Calvani 10-10-2004 10:01 AM
Makes sense otherwise one can break the cable...How did you shortened the cable though?
Humberto-
fast924S 10-10-2004 10:51 AM
Just adjust the nuts on the cable. Also when you adjust the pedal stops, its alot easier to have a buddy watch to make sure when you push the pedal down that the throttle body is opening all the way.
CJFusco 10-10-2004 07:16 PM
that does make sense, because WOT for me is now much shorter than the pedal to the floor
this was not in my set of directions!!!
friendlyguy64 10-12-2004 12:46 PM
why did you spend money on the response cam when you can make it yourself with the old factory one?
Calvani 10-12-2004 12:47 PM
I did not spent any money. I got it as a present... :)
CJFusco 10-13-2004 07:57 AM
ditto
armandodiaz 10-12-2005 08:40 AM
I'm looking for documentation on how you did this, but I can't find any?
BananaClip 10-12-2005 09:07 AM
you should be able to just cut off the arm
CJFusco 10-12-2005 09:09 AM
i believe you turn it upside down and backwards, and drill a new hole for the mount... and then the angle is the same as the welmeiser cam.
This was covered awhile back here... wish i could remember the thread.
