vik vik is offline
Thumbs down 944 wont start
ok, two weeks ago 83 944 auto stalled in parking lot. would not re-start.
waited 4 hours, it started but was sputtering. I raced the engine a few times but would not smooth out. It would not idle on its own. After 10 mins. of rough idle it smelled as if wires were burning. The car was towed.
Under the converter area small puddle of very thick oil. I replaced the converter, and O2 unit. The car starts, drives for about 10 min. and dies. still getting a smell of burning wires. ANY CLUES?????????
Old 10-17-2004, 03:10 PM
AFJuvat's Avatar
Bad news....
Go a compression and a leakdown test.
Sounds like hte cat clogged up, if it clogged bad enough, it will fry the head.
AFJuvat
Es geht nicht darum wie schnell man faehrt, sondern wie gut man schnell fahren kann.
Ihr Brunnen der nutzlosen Porsche Information
Old 10-17-2004, 06:32 PM
vik vik is offline
hte cat? (not a mechanic) what do I have to do?
Thanks for your help.....
Old 10-17-2004, 07:11 PM
vik vik is offline
what is the electrical burning smell, it does not seem to be coming from the engine area, rather the fire wall under and towards rear of engine.
Old 10-17-2004, 07:20 PM
AFJuvat's Avatar
Cat: Catalytic Converter.
Go to an auto parts store and buy a compression tester. Follow the instructions on the package. Post the numbers you get here.
AFJuvat
Old 10-17-2004, 07:21 PM
vik vik is offline
compression results:
1 crank, cyl. 1-3 read 155psi, cyl 4 reads 150psi.
We did this three times with same results.
Vik
Old 10-20-2004, 04:35 PM
