friendlyguy64's Avatar
where is the 924S Auxiliary Air Valve located
Do we have a cold start valve for 87 924S.If yes where is it located?Where is the Auxiliary Air Valve located?
Old 10-22-2004, 12:03 AM
AFJuvat's Avatar
no cold start valve, no aux air valve. You do have a idle stabilizer valve - licated between cyl 2 and 3 intake runner.
AFJuvat
Es geht nicht darum wie schnell man faehrt, sondern wie gut man schnell fahren kann.
Ihr Brunnen der nutzlosen Porsche Information
Old 10-22-2004, 04:10 AM
Will that effect my car not starting up like a cold start?Do those ever need to get replaced
Old 10-22-2004, 05:03 AM
ae1969's Avatar
Send a message via ICQ to ae1969
Not normally...........
But we can help your no start condition.... Just reply to your original post.
Please Help Car Wont Start.
Alex - PCA Polar Region - Boxster Muncher
86' 944 Turbo - Megasquirt - 326 rwhp/340lbft @ 18 psi SOLD
www.edmontonhomelife.com
www.edmontonrealestate.ws
Old 10-22-2004, 11:28 AM
Auxiliary air regulator: Open when engine is cold, closed at operating temp. At least for the 944; assume the 924S is similar. Page 110 of the Haynes manual shows location and has test data. Bad news: Have to remove intake manifold to replace it. As far as I can figure, only on the 83 thru 85 models.
Now on my '84, the stabilization valve is attached to the rear support for the air cleaner......Don't know about the '24S.... Seems as if the later 944 models had an idle speed regulator (930 606 161 00). May be the same with the 24S...
Bob S. former owner of a 1984 silver 944
Old 10-22-2004, 08:16 PM
